1 Reply Latest reply on May 18, 2014 7:59 PM by Wenlan_Du
    acrobat has changed. How do you create a form from current pdf? Used to open form wizard, create using curent pdf, launch. Now launch goes to form central and will syas you must import pdf  form created in acrobat. This is circular.
    changeishard
      Used to be, just a few days ago even, open form wizard, select create using current pdf, select launch. Form created from current PDF.
      Now launch goes to form central and you must pick a template or an file imported to form central.
      When i click import it tells me you must import pdf form created in acrobat, which is what I am trying to do.
      This is a circular answer.
      What changed? How do you use acrobat now to create a form?
