14 Replies Latest reply on May 20, 2014 4:48 AM by Anit_Kumar
    GC overhead limit exceeded
    jfb00 Level 3
      Hi All,
      org.apache.poi java library helps to create an excel files as:
      <cfset setFile = createObject("java","java.io.FileOutputStream") />
              <cfset xlsFile = setFile.init(filepath) />
              <cfset writeableWorkbook = createObject("java","org.apache.poi.xssf.usermodel.XSSFWorkbook") />
              <cfset cellStyleStatic = createObject("java","org.apache.poi.xssf.usermodel.XSSFCellStyle") />
              <cfset region = createObject("java","org.apache.poi.ss.util.CellRangeAddress") />
      <!--- Insert cells and rows --->
              <cfset temp = writeableWorkbook.write(setFile)>
              <cfset temp = setFile.close()>
      The process fail with out of memory error for 17,000 plus rows: GC overhead limit exceeded.
      Anybody knows how to fix this issue?
      Thanks!
        • 1. Re: GC overhead limit exceeded
          jfb00 Level 3
          All,
          I increase the  from 512 to 2048. It process more records but still short memory if i included all records.
          Any ideas?
          • 2. Re: GC overhead limit exceeded
            carl type3 Level 4
            in Server Settings > Java and JVM > JVM Arguments
            increase -XX:MaxPermSize=192m to say 512m. Restart CF to apply.
            HTH, Carl.
            • 3. Re: GC overhead limit exceeded
              BKBK Adobe Community Professional & MVP
              Shouldn't the 'write' line involve the file? What about replacing
              with
              <cfset xlsFileOut = createObject("java","java.io.FileOutputStream").init(filepath) />
              and
              with
              <cfset temp = writeableWorkbook.write(xlsFileOut)>
              <cfset temp = xlsFileOut.close()>
              • 4. Re: GC overhead limit exceeded
                jfb00 Level 3
                Thanks for your reply and help.
                I did the change BKBK.
                Carl : that helps, i can do more than 17K but no more than 40K. I am getting Error: Java heap space.
                Any ideas?
                • 5. Re: GC overhead limit exceeded
                  Anit_Kumar Adobe Employee
                  Setting a high value for Xmx or permgen is probably not a good idea. You need to tune the values, not exactly, but appropriately. You may refer to http://www.adobe.com/devnet/coldfusion/articles/coldfusion_performance.html for performance tuning.
                  You can use jmeter to test whether the Java heap space error is due to, heap memory or non-heap memory.
                  For load testing, download jmeter from the link https://jmeter.apache.org/download_jmeter.cgi
                  Here are the steps to be followed:-
                  1. Test paln -> Right click --> Add - Thread group
                  2. Right click on Thread group --> Add - Sampler- HTTP Request
                  3. Right click HTTP Request --> Add- Listener - View Results in Table
                  4. Click on HTTP REquest  and enter the server name like localhost or ip address, then port number of your site like 80
                  5. Enter the path as : http://localhost:81/hello.cfm
                  6. Click on Thread Group in left panel. Increase the number of threads as 40 or something like that. Enter the loop count like 5000 or so
                  7. Now click on the green start icon at top and click on view results in table
                  NOTE: click on apache-jmeter-2.10.zip under binaries
                  If the non-heap memory is increasing then, the perm gen value needs to be recalculated. Whereas, if the heap memory is increasing then the Xmx needs to changed.
                  Hope that helps
                  Regards,
                  Anit Kumar
                  • 6. Re: GC overhead limit exceeded
                    jfb00 Level 3
                    Thank for you reply and help.
                    In the view results i see only sample,start time,thread name, label, sample time, status, bytes, latency:
                    Example
                    6408711:40:34.847Thread Group 1-18HTTP Request4587Warning71514587
                    6408811:40:34.849Thread Group 1-30HTTP Request9098Warning71519098
                    6408911:40:34.849Thread Group 1-17HTTP Request9098Warning71519098
                    6409011:40:39.335Thread Group 1-40HTTP Request9324Warning71519323
                    6409111:40:39.392Thread Group 1-3HTTP Request9267Warning71519267
                    6409211:40:39.392Thread Group 1-5HTTP Request9267Warning71519267
                    6409311:40:48.659Thread Group 1-40HTTP Request94081Warning23580
                    6409411:40:39.454Thread Group 1-23HTTP Request103287Warning23580
                    6409511:40:39.454Thread Group 1-19HTTP Request103286Warning23580
                    6409611:40:39.393Thread Group 1-21HTTP Request103350Warning23580
                    6409711:40:39.454Thread Group 1-29HTTP Request103291Warning23580
                    6409811:40:39.454Thread Group 1-34HTTP Request103293Warning23580
                    What is the non-heap memory and heap memory?
                    • 7. Re: GC overhead limit exceeded
                      I accidentally typed the incorrect tool. Use JConsole or JVisualvm to find the memory, causing the error.
                      It seems like, you JVM needs tuning (http://docs.oracle.com/cd/E13222_01/wls/docs81/perform/JVMTuning.html). Heap Memory, which is the storage for Java objects and Non-Heap Memory, which is used by Java to store loaded classes and other meta-data. Thus Xms and Xmx contribute to Heap memory and XX:MaxPermSize or permgen to Non-heap memory. You can get more details at Heap and Non-heap.
                      Regards,
                      Anit Kumar
                      • 8. Re: GC overhead limit exceeded
                        jfb00 Level 3
                        I see this:
                        Time:  2014-05-19 17:30:09
                        Used:      21,549 kbytes
                        Committed:      30,208 kbytes
                        Max:  3,714,048 kbytes
                        GC time:  0.281 seconds on PS MarkSweep (3 collections)
                          0.121 seconds on PS Scavenge (28 collections)
                        The heap memory for most of the time was 50%, it when to 75% and at the end use 100% for little bit time.
                        The non-heap memory was 25% all the time.
                        How can I determine the values to use? Sorry but I am trying to learn this.
                        • 9. Re: GC overhead limit exceeded
                          carl type3 Level 4
                          Agreed. One would do well to set an initial setting for Xms (initial heap) and PermGen (EG -XX:PermSize=256m  non heap) as well as tuned maximum.
                          You might like to watch a CF Java presentation I did end of 2010.  Versions have changed since then and 64 bit alters the Java memory scope however the principles are still the same.
                          http://experts.adobeconnect.com/p55663036/
                          This talk demonstrated use of Jconsole, more to look at CF tomcat connector than memory but again that might provide you some assistance with using Jconsole.
                          http://experts.adobeconnect.com/p8l51p4s9m4/
                          Regards, Carl.
                          • 10. Re: GC overhead limit exceeded
                            These objects are taking memory space, but it is unclear what they are there for. As they stand, they are redundant.
                            • 11. Re: GC overhead limit exceeded
                              They seems to me, Apache poi for excel. Though i am not sure and even unclear about their usage here.
                              Regards,
                              Anit Kumar
                              • 12. Re: Re: GC overhead limit exceeded
                                jfb00 Level 3
                                YES, it is an java excel poi. Here is the code, maybe you can help us to find out the memory leak.
                                The code is part of a function that I pass parameter such as the data, the column names and formats.
                                Thanks for all comments and help!
                                <cfif not DirectoryExists("#getDirectoryFromPath(getCurrentTemplatePath())#excelDumpFiles")>
                                            <cfdirectory action="create" directory="#getDirectoryFromPath(getCurrentTemplatePath())#excelDumpFiles">
                                        </cfif>
                                        <cfset filepath = "#getDirectoryFromPath(getCurrentTemplatePath())#excelDumpFiles\#fileName#" />
                                        <cfset xlsFile = createObject("java","java.io.FileOutputStream").init(filepath) />
                                        <cfset writeableWorkbook = createObject("java","org.apache.poi.xssf.streaming.SXSSFWorkbook").init(1000) />
                                        <!--- set up data formats --->
                                        <cfset moneyFormat = writeableWorkbook.createDataFormat() />
                                        <cfset wholeNumMoneyFormat = writeableWorkbook.createDataFormat() />
                                        <cfset dec1Format = writeableWorkbook.createDataFormat() />
                                        <cfset dec2Format = writeableWorkbook.createDataFormat() />
                                        <cfset dec3Format = writeableWorkbook.createDataFormat() />
                                        <cfset percentFormat = writeableWorkbook.createDataFormat() />
                                        <cfset wholeNumFormat = writeableWorkbook.createDataFormat() />
                                        <cfset moneyStyle = writeableWorkbook.createCellStyle() />
                                        <cfset moneyStyle.setDataFormat(moneyFormat.getFormat("$##,####0.00_);[Red]($##,####0.00)")) />
                                        <cfset wholeNumMoneyStyle = writeableWorkbook.createCellStyle() />
                                        <cfset wholeNumMoneyStyle.setDataFormat(wholeNumMoneyFormat.getFormat("$##,####0_);[Red]($##,####0)")) />
                                        <cfset dec1Style = writeableWorkbook.createCellStyle() />
                                        <cfset dec1Style.setDataFormat(dec1Format.getFormat("##,####0.0_);[Red](##,####0.0)")) />
                                        <cfset dec2Style = writeableWorkbook.createCellStyle() />
                                        <cfset dec2Style.setDataFormat(dec2Format.getFormat("##,####0.00_);[Red](##,####0.00)")) />
                                        <cfset dec3Style = writeableWorkbook.createCellStyle() />
                                        <cfset dec3Style.setDataFormat(dec3Format.getFormat("##,####0.000_);[Red](##,####0.000)")) />
                                        <cfset percentStyle = writeableWorkbook.createCellStyle() />
                                        <cfset percentStyle.setDataFormat(percentFormat.getFormat("##,####0.00_)%;[Red](##,####0.00)%")) />
                                        <cfset wholeNumStyle = writeableWorkbook.createCellStyle() />
                                        <cfset wholeNumStyle.setDataFormat(wholeNumFormat.getFormat("##,####0_);[Red](##,####0)")) />
                                        <cfset numberOfLoops = (ArrayLen(arguments) - 1) / 5 />
                                        <cfset argTemp = 1 />
                                        <cfloop from="1" to="#numberOfLoops#" index="argIndex">
                                            <cfif arguments[argIndex + argTemp] >
                                                    <cfset argTemp = argTemp + 1 />
                                                    <cfset rowCount = 0>
                                                    <!--- NEW SHEET --->
                                                    <cfset newSheet = writeableWorkbook.createSheet() />
                                                    <cfset temp = writeableWorkbook.setSheetName(sheetNumber, arguments[argIndex + argTemp]) />
                                                    <!--- add meta data only for the first workbook or worksheet --->
                                                    <cfif sheetNumber eq 0>
                                                        <cfset newSheet.addMergedRegion(region.init(0,0,0,20))> <!--- first row, last row, first col, last col --->
                                                        <cfset newRow = newSheet.createRow(javaCast("int",0))>
                                                        <cfset newCell = newRow.createCell(javaCast("int",0))>
                                                        <cfset temp = newCell.setCellType(javaCast("int",1))> <!--- string --->
                                                        <cfset temp = newCell.setCellValue(javaCast("string",reqString))>
                                                        <cfset rowCount = rowCount + 1 />
                                                    </cfif>
                                                    <!--- Get Data --->
                                                    <cfset qryExcelData = arguments[argIndex + argTemp] />
                                                    <!--- create column span headers --->
                                                    <cfset newRow = newSheet.createRow(javaCast("int",rowCount)) />
                                                    <cfset styleAlignCenter = writeableWorkbook.createCellStyle() />
                                                    <cfset styleAlignCenter.setAlignment(cellStyleStatic.ALIGN_CENTER) />
                                                    <cfloop from="1" to="#ArrayLen(arguments[argIndex + argTemp])#" index="index">
                                                        <cfset newSheet.addMergedRegion(region.init(rowCount,rowCount,javaCast("int",StructFind(arguments[argIndex + argTemp][index],"spanStart")),javaCast("int",StructFind(arguments[argIndex + argTemp][index],"spanEnd"))))> <!--- first row, last row, first col, last col --->
                                                        <cfset newCell = newRow.createCell(javaCast("int",StructFind(arguments[argIndex + argTemp][index],"spanStart")))>
                                                        <cfset newCell.setCellStyle(styleAlignCenter)>
                                                        <cfset temp = newCell.setCellValue(javaCast("string",StructFind(arguments[argIndex + argTemp][index],"columnHeader")))>
                                                    </cfloop>
                                                    <!--- create column headers --->
                                                    <cfset rowCount = rowCount + 1>
                                                    <cfset newRow = newSheet.createRow(javaCast("int",rowCount))>
                                                        <cfset newCell = newRow.createCell(javaCast("int",index-1))>
                                                    </cfloop>
                                                    <!--- Loop thru the data --->
                                                    <cfset colLength = ArrayLen(arguments[argIndex + argTemp]) />
                                                    <!--- <cfset colLength = 7 /> --->
                                                    <cfoutput query="qryExcelData">
                                                        <cfloop from="1" to="#colLength#" index="index">
                                                            <cfset tempCol = StructFind(arguments[argIndex + argTemp][index],'columnName') />
                                                            <cfset tempFormat = StructFind(arguments[argIndex + argTemp][index],'excelFormat') />
                                                            <cfif isNumeric(qryExcelData["#tempCol#"][qryExcelData.currentRow])>
        <cfif FindNoCase(".",tempFormat)>
        <cfset decimalLen = Len(Trim(REReplace(tempFormat,"[$,.]","","ALL"))) />
        </cfif>
        <cfif tempCol eq "ColumnNameA">
        <cfset newCell.setCellType(javaCast("int",1)) /> <!--- string --->
        <cfset Evaluate("qryExcelData.#tempCol#") />
        <cfset newCell.setCellValue(javaCast("string",IIF(temp,'TRUE','FALSE'))) />
        <cfelse>
        <cfset temp = newCell.setCellType(javaCast("int",0))> <!--- numeric --->
        <cfif FindNoCase(",",tempFormat) and not FindNoCase("$",tempFormat)>
        <cfif decimalLen eq 1>
        <cfset temp = newCell.setCellStyle(dec1Style)>
        <cfelseif decimalLen eq 2>
        <cfset temp = newCell.setCellStyle(dec2Style)>
        <cfelseif decimalLen eq 3>
        <cfset temp = newCell.setCellStyle(dec3Style)>
        <cfelse>
        <cfset temp = newCell.setCellStyle(wholeNumStyle)>
        </cfif>
        <cfelseif FindNoCase("$",tempFormat)>
        <cfif NOT FindNoCase(".",tempFormat)>
        <cfset temp = newCell.setCellStyle(wholeNumMoneyStyle)>
        <cfelse>
        <cfset temp = newCell.setCellStyle(moneyStyle)>
        </cfif>
        </cfif>
        <cfset temp = newCell.setCellValue(javaCast("double",qryExcelData["#tempCol#"][qryExcelData.currentRow]))>
        </cfif>
                                                            <cfelseif isDate(qryExcelData["#tempCol#"][qryExcelData.currentRow])>
        <cfset tempVal = qryExcelData["#tempCol#"][qryExcelData.currentRow] />
        <cfif second(tempVal) gt 0>
        <cfset tempVal = '#DateFormat(tempVal,"MM/DD/YYYY")# #TimeFormat(tempVal,"HH:mm:ss")#' />
        <cfelse>
        <cfset tempVal = DateFormat(tempVal,"MM/DD/YYYY") />
        </cfif>
        <cfset newCell.setCellValue(javaCast("string",tempVal))>
                                                            <cfelse>
        <cfif tempCol neq "">
        <cfset temp = newCell.setCellValue(javaCast("string",qryExcelData["#tempCol#"][qryExcelData.currentRow]))>
        <cfelse>
        <cfset temp = newCell.setCellValue(javaCast("string","#tempFormat#"))>
        </cfif>
                                                            </cfif>
                                                            <cfset decimalLen = 0 />
                                                        </cfloop>
                                                    </cfoutput>
                                                    <!--- auto expand columns --->
                                                    <cfloop from="0" to="#ArrayLen(arguments[argIndex + argTemp])#" index="index">
                                                        <cfset newSheet.autoSizeColumn(javaCast("int",index)) />
                                                    </cfloop>
                                            <cfset sheetNumber = sheetNumber + 1>
                                            <cfelse>
                                                <cfset argargTemp + 5 />
                                            </cfif>
                                        </cfloop>
                                        <!--- Write Excel File --->
                                        <cfset writeableWorkbook.write(xlsFile)>
                                        <cfset xlsFile.close()>
                                        <cfset writeableWorkbook.dispose() />
                                        <cfcatch>
                                            <cfset dataStatus = "Excel creation failed.<br>#cfcatch.message# #cfcatch.detail#" />
                                            <!--- <cfset application.debug(cfcatch) /><cfabort> --->
                                        </cfcatch>
                                        </cftry>
                                • 13. Re: Re: GC overhead limit exceeded
                                  jfb00 Level 3
                                  It works fine now. The key was in this line:
                                  I didn't have the 1000 buffer before. Thanks!
                                  • 14. Re: Re: GC overhead limit exceeded
                                    That is great. Please mark the thread as answered, so that others are benefited with the same.
                                    Regards,
                                    Anit Kumar
