1 Reply Latest reply on May 18, 2014 1:12 AM by Damienned
    split txt-file into 3 xml files
    Damienned
      I'm trying to create 3 xml files from 1 txt file in javascript.
      What i have sofar:
      A text file containing:
      GP0006896###SunGold-3 small###00###Zespri Service Centre NV###KLT0000110###16950###tray Kiwi SunGold 3-pack Small###JWM###ZESPRI-3-D$$$
      GP0012816###S500-R012336###00###Poppies Nederland BV###KLT0000081###17890###Plus slagroomsoes 250g###JWM###CULI-10-B$$$
      GP0009000###test###01###Just a test###KLT0001010###20596###Dit is een test regel###Standaard###TEST-01-B$$$
      The script:
      // Set variable
      var txtfolderpath = app.path+'/XML_converter/';
      var txtfilename = 'txt_to_xml.txt';
      var txtfilelocation = File(txtfolderpath+txtfilename);
      var xmlfolderpath = app.path+'/XML_converter/xml/';
      var retChar = eval('String.fromCharCode(13)');
      var presscancelbutton = 0;
      var appversion = app.version;
      var appversionarray = appversion.split('.');
      appversion = new Number(appversionarray[0]);
      var xmlstring='';
      //Scriptfolderpathcheck
      #target Illustrator
      var pathcheck = File($.fileName).parent.fsName;
      infopanelmenu();
      function infopanelmenu(){
          res =
          "dialog { \
              text:'TXT to XML:', \
              properties:{resizeable:false}, \
              margins: [0,0,0,0], \
                  imagegroup: Group { orientation:'stack', preferredSize: [400, 221], alignChildren:'bottom', \
                      jobgroup: Group { orientation:'column',  margins: [0,0,0,20], \
                          infopanelgroup: Panel { orientation:'column', preferredSize: [360, 20], alignChildren:'top', text: 'TXT to XML conversion', \
                              xmlgroup: Group { orientation: 'row', alignment: 'left', \
                                  s: StaticText { text:'XML converted : ' }, \
                                  s2: StaticText { text:'0' }, \
                              statusgroup: Group { orientation: 'row', alignment: 'left', \
                                  s: StaticText { text:'Status              : ' }, \
                                  s2: StaticText { text:'Ready to start' }, \
                          infopanelbuttons: Group { orientation: 'row', alignment: 'center', \
                          cancelBtn: Button { text:'Cancel', properties:{name:'cancel'} }, \
                          applyBtn: Button { text:'Start', properties:{name:'apply'} }, \
          wininfo = new Window (res);
          wininfo.frameLocation = [100, 100];
          // Buttons
          wininfo.imagegroup.jobgroup.infopanelbuttons.cancelBtn.onClick = function () {
              presscancelbutton = presscancelbutton - 1;
              wininfo.close();
          wininfo.imagegroup.jobgroup.infopanelbuttons.applyBtn.onClick = function () {
              buildxml();
          wininfo.center();
          wininfo.show();
      function buildxml(){
          txtfilelocation.open('read');
          txtfile = txtfilelocation.read();
          var xmlarray = txtfile.split('$$$');
          wininfo.imagegroup.jobgroup.infopanelgroup.statusgroup.s2.text = 'Running';
          wininfo.imagegroup.jobgroup.infopanelbuttons.applyBtn.text = 'Running';
          wininfo.imagegroup.jobgroup.infopanelbuttons.applyBtn.enabled = false;
          // For lus schrijven
          for (i=0; i<xmlarray.length-1; i++) {
              var subxmlarray = xmlarray[i].split('###');
              var counter = i+1;
              var xmlstring = '';
              xmlstring = xmlstring + '<?xml version="1.0" encoding="UTF-8"?>'+retChar;
              xmlstring = xmlstring + '<xml>'+retChar;
              xmlstring = xmlstring + '<gp_number>'+subxmlarray[0]+'</gp_number>'+retChar;
              xmlstring = xmlstring + '<artikelnummer>'+subxmlarray[1]+'</artikelnummer>'+retChar;
              xmlstring = xmlstring + '<versienummer>'+subxmlarray[2]+'</versienummer>'+retChar;
              xmlstring = xmlstring + '<klantnaam>'+subxmlarray[3]+'</klantnaam>'+retChar;
              xmlstring = xmlstring + '<klantnummer>'+subxmlarray[4]+'</klantnummer>'+retChar;
              xmlstring = xmlstring + '<ID>'+subxmlarray[5]+'</ID>'+retChar;
              xmlstring = xmlstring + '<artikelomschrijving>'+subxmlarray[6]+'</artikelomschrijving>'+retChar;
              xmlstring = xmlstring + '<workflow>'+subxmlarray[7]+'</workflow>'+retChar;
              xmlstring = xmlstring + '<stans>'+subxmlarray[8]+'</stans>'+retChar;
              xmlstring = xmlstring + '</xml>'
              wininfo.imagegroup.jobgroup.infopanelgroup.xmlgroup.s2.text = counter;
              alert(xmlstring); // see if the stingbuild works <-- works here 3 times
              // Save function
              var filename = subxmlarray[0]+'.xml';
              var xmlsavelocation = File(xmlfolderpath+filename);
              xmlsavelocation.open('w');
              xmlsavelocation.writeln(xmlstring);// save the string <-- works here 3 times but generates two empty documents!
              xmlsavelocation.close();
          txtfilelocation.close();
          wininfo.imagegroup.jobgroup.infopanelgroup.statusgroup.s2.text = 'Ready';
          wininfo.imagegroup.jobgroup.infopanelbuttons.applyBtn.text = 'Start';
          wininfo.imagegroup.jobgroup.infopanelbuttons.applyBtn.enabled = true;
      The output:
      You'll see that i get 3 files but 2 are 0 bytes.
      The question:
      Why can't i save the other two strings in a xml file?
      Thanks Daniel
