5 Replies Latest reply on May 19, 2014 10:05 PM by Jump_Over
    Anchor required
    kanaga kumar
      Dear Friends,
      I need “Para_No” paragraph style should be placed in “archor format” in next para begining of text. This is urgent request. Kindly help in this regard.
      Actual page:
      MY Requirement:
      Thanks in advance,
      kanaga kumar. k
        • 1. Re: Anchor required
          BEGINNER_X Level 3
          Hi Kanaga,
          Before run the script, please open the document and library.
          Please create the below:
          Paragraph Styles = "Para_No"
          Library Asset Name = "ANNO"
          Object Style Name = "Object Styles"
          And also i am not tested in my end. Kindly find the code below:
          var myDoc = app.documents[0];
          var myLib = app.libraries[0];
          app.findTextPreferences = NothingEnum.nothing;
          app.changeTextPreferences = NothingEnum.nothing;
          app.findTextPreferences = null;
          app.findTextPreferences.appliedParagraphStyle= "Para_No";
          myFind = myDoc.findText(true);
          var myCount=0;
              for (var i=0; i<myFind.length; i++)
                  var myPara = myFind[i].texts[0];
                  myText = myLib.assets.item ("ANNO").placeAsset (myFind[i].insertionPoints[-1])[0];
                  myPara.move(LocationOptions.AT_END, myText.insertionPoints[-1]);
                  myText.appliedObjectStyle = myDoc.objectStyles.item ("Object Styles");
          alert(myCount+" ANNOs are Placed Successfully...");
          • 2. Re: Anchor required
            Jump_Over Level 5
            What to do:
            • find all occurrences where thisPara is applied
            • iterate through backwards
            • add a textFrame at last insertionPoint
            • set a textFrame properties
            • move text and fit textFrame to contents
            app.findTextPreferences.appliedParagraphStyle = "Para_Num";
              mFound = app.activeDocument.findText(),
              len = mFound.length,
              currWidth, tarText, tarIP, currFrame, currGB,
              old_VOrigin = app.activeDocument.viewPreferences.verticalMeasurementUnits,
              old_HOrigin = app.activeDocument.viewPreferences.horizontalMeasurementUnits;
            app.activeDocument.viewPreferences.horizontalMeasurementUnits =
              app.activeDocument.viewPreferences.verticalMeasurementUnits =
            while (len-->0) {
              tarText = mFound[len];
              currWidth = tarText.lines[0].endHorizontalOffset - tarText.lines[0].horizontalOffset + 10;
              tarIP = tarText.insertionPoints[-1];
              currFrame = tarIP.textFrames.add();
              setFrame (currFrame);
              currGB = currFrame.geometricBounds;
              currGB = [currGB[0], currGB[3] - currWidth, currGB[2], currGB[3]];
              currFrame.geometricBounds = currGB;
            app.activeDocument.viewPreferences.horizontalMeasurementUnits = old_HOrigin;
            app.activeDocument.viewPreferences.verticalMeasurementUnits = old_VOrigin;
            function setFrame (mAnchored){
              with (mAnchored) {
              anchoredObjectSettings.anchoredPosition = AnchorPosition.ANCHORED;
              anchoredObjectSettings.anchorPoint = AnchorPoint.BOTTOM_RIGHT_ANCHOR;
              anchoredObjectSettings.horizontalReferencePoint = AnchoredRelativeTo.TEXT_FRAME;
              anchoredObjectSettings.verticalReferencePoint = VerticallyRelativeTo.LINE_BASELINE;
              textFramePreferences.insetSpacing = [0,0,0,1];
              textFramePreferences.verticalJustification = VerticalJustification.BOTTOM_ALIGN;
            • 3. Re: Anchor required
              kanaga kumar Level 1
              Dear Siraj,
              Thanks for your timely help, and its working fine. Also i need two kind of clarifications based on above mentioned requirement:
              1. Multiple styles how to used same method
              2. Common arts need to place in same method
              Kindly advice and it is possible?
              kanaga kumar. k
              • 4. Re: Anchor required
                hasvi Level 1
                I try to run this script, but my Indesign file is closed when I run this script, can you help me?
                • 5. Re: Anchor required
                  Jump_Over Level 5
                  How big is mFound.length on your side?
                  Is "live pages" feature active in your doc?
                  Did you try to debug a code by running it from ESTK with breakpoints inserted?
                  Try to run findText() with smaller target than app.activeDocument
                  For example: app.activeDocument.stories[0].paragraphs.itemByRange(0,50).texts[0];
                  PS Last thing I thought about: Be sure to run this code with "Para_Num" style applied to plain textFrame contents. I mean do not run it if some part are moved into anchored textFrames already.
