1. Re: Trying to generate PDF - 'No table of contents entries found'
Peter Grainge May 19, 2014 6:09 AM (in response to DNKW)Check your Macro settings in Word. They need to be set to the lowest level.
If that is not it, try generating from one of the sample projects and then post back here.
Click Open on the RoboHelp Starter page and then click Samples in the ribbon on the left.
2. Re: Re: Trying to generate PDF - 'No table of contents entries found'
DNKW May 19, 2014 6:39 AM (in response to Peter Grainge)Thank you very much for the prompt reply, Peter.
I have set the Macro settings to low as suggested, and the problem remains.
Also, the sample projects generated as docs/pdfs fine.
Furthermore, (my apologies, I omitted to mention this) our other software's help file (we have two products) generates docs/pdfs without a problem.
Thank you for your help.
Dan
3. Re: Re: Trying to generate PDF - 'No table of contents entries found'
Peter Grainge May 19, 2014 7:00 AM (in response to DNKW)Create a new print layout, not a duplicate. Run through the wizard with the defaults other than setting it to only create a Word document on the first page and applying your template on the last page.
Any better then?
4. Re: Re: Trying to generate PDF - 'No table of contents entries found'
DNKW May 19, 2014 7:10 AM (in response to Peter Grainge)Fantastic - that's worked.
Many thanks for help!
Dan
5. Re: Re: Trying to generate PDF - 'No table of contents entries found'
Peter Grainge May 19, 2014 7:38 AM (in response to DNKW)Occasionally something corrupts a layout. Fortunately it is rare.
6. Re: Re: Trying to generate PDF - 'No table of contents entries found'
DNKW May 19, 2014 8:03 AM (in response to Peter Grainge)Thank you.
