18 Replies Latest reply on Jun 4, 2007 9:28 AM by insuractive
    Populating a PDF File from ColdFusion
    Level 7
      I wanted to populate a pfd file from coldfusion and I found this online:
      http://www.school-for-champions.com/coldfusion/cftopdf.htm
      When I submit the form.. I then show a link [view pdf].. only when I click
      on that lick I get a message saying
      Adobe acrobat: the file is damaged and could not be repaired.
      Has anyone used this method successfully? If so, would like to hear some
      suggestions.
      The PDF template I created just have 2 fields. firstname lastname (which
      matches cfm form).
      Thanks in advance
      1. Create PDF document to populate
      Create the document you want to populate. This document could be done in
      Microsoft Word, as an HTML page or using some drawing application. Then
      create a PDF file of that document.
      You must have Adobe Acrobat or the equivalent to create a PDF file.
      Typically, the easiest way to create a PDF is to click File > Print and
      select Acrobat Distiller as your printer.
      2. Enter fields with Acrobat
      Once the document is in the PDF format, open it in Acrobat. Use the menu bar
      tools to define your fields.
      a.. Use the Form Tool to define the various text fields, give each a name,
      and designate the font type and size. The field name should correspond to
      the name of the data you will input.
      b.. Use the Text Tool to modify areas of text. You may have to change the
      font or font size. It is not the easiest tool to use.
      This will be your PDF template.
      3. Create a ColdFusion page to populate the PDF
      Create a ColdFusion form to gather data from input over the Internet or from
      a database query. This page or an action page will provide the means to
      populate the PDF file.
      The code you use will depend on the method or software you decide to use.
      Options will be explained in the next section.
        • 1. Re: Populating a PDF File from ColdFusion
          BLXWebMaster
          What version of PDF are you using? Are you creating your PDF Form in designer? If you are trying to Pre-Populate a PDF Form, this technique will not work in that this will not preserve your Form. With the recent versions of PDF, Adobe hase changed the technology to be XML and you are trying to populate your PDF using FDF. I don't think that this can be done.
          I would stay away from FDF.
          Although there are several tools that will allow you to do this, most of them rely on the old FDF format.
          I would suggest checking out XPAAJ. This is a free api for Coldfusion users and offers a decent basic pre-population of PDF's.
          Written by our friend Ben Forta, you can check it out here.
          http://www.forta.com/blog/index.cfm/2006/7/27/cf_pdfform
          • 2. Re: Populating a PDF File from ColdFusion
            Level 7
            this works w/the version of iText that comes w/cf7 (powers cfdocument).
            <cfscript>
            newFile=expandPath("registered.pdf");
            // pdf containing your form
            pdfFile=expandPath("simpleRegistrationForm.pdf");
            fos=createObject("java","java.io.FileOutputStream").init(newFile);
            reader=createObject("java","com.lowagie.text.pdf.PdfReader").init(pdfFile);
            pdfStamper=createObject("java","com.lowagie.text.pdf.PdfStamper").init(reader, fos);
            form1 = pdfStamper.getAcroFields();
            // form fields
            form1.setField("name", "Bruno Lowagie");
            form1.setField("address", "Baeyensstraat 121, Sint-Amandsberg");
            form1.setField("postal_code", "BE-9040");
            form1.setField("email", "bruno@lowagie.com");
            pdfStamper.setFormFlattening(false);
            pdfStamper.close();
            // in case you to "flatten" the form
            newFile=expandPath("registered_flat.pdf");
            pdfStamper2=createObject("java","com.lowagie.text.pdf.PdfStamper").init(reader,
            fos);
            form2=pdfStamper2.getAcroFields();
            form2.setField("name", "Bruno Lowagie");
            form2.setField("address", "Baeyensstraat 121, Sint-Amandsberg");
            form2.setField("postal_code", "BE-9040");
            form2.setField("email", "bruno@lowagie.com");
            pdfStamper2.setFormFlattening(true);
            pdfStamper2.close();
            </cfscript>
            • 3. Re: Populating a PDF File from ColdFusion
              insuractive Level 3
              I would second BLXWebMaster's suggestion. We use Ben's <cf_pdfform> tag quite a lot to autofill PDF forms. It even boasts the ability to read data back from PDF forms into CF.
              Went to a CF Version 8 Preview today - CF Version 8 will have a <cfpdfform> tag built in to it that will allow you to do pretty much the same thing.
              • 4. Re: Populating a PDF File from ColdFusion
                BKBK Adobe Community Professional & MVP
                shhh!
                • 5. Re: Populating a PDF File from ColdFusion
                  tclaremont Level 2
                  Its not really a secret. It is in the version of CF8 that I am previewing.
                  • 6. Re: Populating a PDF File from ColdFusion
                    Level 7
                    thanks for the suggestion, I was able to get this to work.
                    now I was wondering how i can have it instead of displaying the pdf.. create
                    the pdf and save it and only show it when i click <preview>
                    "BLXWebMaster" <webforumsuser@macromedia.com> wrote in message
                    news:f2fi63$c1e$1@forums.macromedia.com...
                    > designer?
                    > in
                    > Adobe
                    > PDF
                    > them
                    > users
                    • 7. Re: Populating a PDF File from ColdFusion
                      insuractive Level 3
                      PaulH's example using iText will generate a new PDF file for you, which you can later "preview" in the browser.
                      • 8. Re: Populating a PDF File from ColdFusion
                        Level 7
                        Hi, I need your help again.. And if you can do this for me; i will pay for
                        your time. just let me know. because i need this project wrap up in the next
                        28 hours.
                        I've used the Ben Forta (cf_PDFFROM) and i'm able to get the pdf. (great)
                        now i need to suppress blank lines.
                        my pdf is a business card template.
                        on the left top down
                        firstname middle name lastname
                        job title
                        address1
                        address2
                        address3
                        www.whatever.com
                        on the right bottom up:
                        phone:
                        fax:
                        mobile:
                        email:
                        aim:
                        there's where I'm stuck:
                        if a user does not enter a fax number... I want the PDF to move 'phone:'
                        down 1 line and not show the word 'fax'.
                        PLEASE can someone point me in the right direction OR tell me you can do it
                        quickly. contact me and i'll pay you.
                        thanks in advance!
                        > designer?
                        > in
                        > Adobe
                        > PDF
                        > them
                        > users
                        • 9. Populating a PDF File from ColdFusion
                          efecto747 Level 1
                          Could you perhaps create several templates to match the various data configurations and select the one most appropriate for each record?
                          ie. create a template without the fax and when a record doesn't have a fax number, use that template..
                          • 10. Re: Populating a PDF File from ColdFusion
                            tclaremont Level 2
                            Sounds like a scenario for....
                            CFIF Fax is null, use template 1
                            CFIF Address2 is null, use template 2
                            • 11. Re: Populating a PDF File from ColdFusion
                              Level 7
                              thanks.. I'm creating different templates now!
                              although I still have to find a solution for down the road..
                              anyone knows Adobe LiveCycle Designer scripting ?
                              "efecto747" <webforumsuser@macromedia.com> wrote in message
                              news:f3lfng$srr$1@forums.macromedia.com...
                              > Could you perhaps create several templates to match the data and then
                              > select
                              • 12. Re: Populating a PDF File from ColdFusion
                                Level 7
                                you're going to need an awful lot of templates ;-)
                                • 13. Re: Populating a PDF File from ColdFusion
                                  indranie Level 1
                                  exactly.. that's why for a short term solution 1 day.. i did a few templates.
                                  but i need to work off of ONE master. and i'm still having problem suppress the lines when it's empty.
                                  • 14. Re: Populating a PDF File from ColdFusion
                                    tclaremont Level 2
                                    Hey, I didn't say it wouldn't be labor intensive! :-)
                                    • 15. Re: Populating a PDF File from ColdFusion
                                      insuractive Level 3
                                      What about using iText to create your PDF programatically? Then you could position your content however you'd like.
                                      • 16. Re: Populating a PDF File from ColdFusion
                                        Level 7
                                        for anything complex i always use iText (anything less complex you *cannot* beat
                                        cfdocument, it makes PDF production drop dead simple, especially from HTML). you
                                        probably want to use the latest version of iText & the easiest way to do that &
                                        *not* break cfdocument is to use mark mandel's javaloader to "load" the new
                                        iText jar ( http://javaloader.riaforge.org/ ). use iText to read the PDF form,
                                        extracting the field values & then simply "burn" a new PDF using the form data.
                                        if you do a lot of work w/iText you should probably get bruno's book:
                                        http://itext.ugent.be/itext-in-action/
                                        it's worth it.
                                        • 17. Populating a PDF File from ColdFusion
                                          BLXWebMaster Level 1
                                          So, you have 5 fields like what is below. If the value for any field is Null, you want to supress that line from being drawn.
                                          Are these individual fields? If so, do the need to be? What about creating 1 Text area field and populating the whole thing instead of seperately. This way, in your CF code you could do somethign like this....
                                          <cfsavecontent variable="ContactInfo">
                                          <cfif Form.phone NEQ ''>phone: #Form.Phone# <BR></cfif>
                                          <cfif Form.fax NEQ ''>fax: #Form.fax# <BR></cfif>
                                          <cfif Form.mobile NEQ ''>mobile: #Form.mobile# <BR></cfif>
                                          <cfif Form.email NEQ ''>email: #Form.email# <BR></cfif>
                                          </cfsavecontent>
                                          Then just pass ContactInfo to your PDF.
                                          Allen
                                          • 18. Re: Populating a PDF File from ColdFusion
                                            insuractive Level 3
                                            Allen,
                                            Unfortunately, this particular case IS is trying to precisely position the elements in the PDF (its a business card template), so the HTML to PDF via CFdocument route isn't really going to work for him.
                                            I do have to say, the few times I have used iText it's been pretty effective. You may run into some issues in a hosted environment (restricted use of CreateObject() or <cfobject>, etc). Mark Mandel's javaloader is a pretty cool tool, thanks for the link Paul.
