1 Reply Latest reply on May 19, 2014 10:14 PM by pwillener
    Changes in Adobe Flash Player Settings Manager are not stored
    grauemaus
      Flash Player installs fine. Lastest version: 13.0.0.214
      Windows 7.
      Problem is seen with Firefox, Waterfox, Palemoon and Internet Explorer (64-bit).
      Actually, the problem is probably not related to the browser.
      Problem: websites that use the Flash Player to play videos do not retain changes in the volume.
      Upon inspection, it seems that:
      1) The amount of storage allowed for websites is set to 0.
      2) When trying to change this setting, it seems impossible to change the setting.
      I use this webpage:
      https://www.adobe.com/support/documentation/en/flashplayer/help/settings_manager03.html
      The second tab is called "global storage settings panel".
      The amount of diskspace allowed is set to "None".
      When I move the slider, I can move the slider.
      When I click another tab, and then click the storage settings panel again, the value is reset to "None" again.
      This also happens why I try to change the notification settings, or any other setting in one of those tabs.
      The changes just don't seem to stick.
      I have uninstalled Flash Player, and re-installed it. Didn't solve the problem.
      I've done the same with Flash Player for Internet Explorer, and tested that. No difference. The changes still do not stick.
      I have uninstalled the Flash Player(s).
      I then deleted the %appdata%\Adobe and %appdata\MacroMedia folders.
      I then reinstalled the Flash Player. No success.
      I have used the windows-control-panel "Flash Player (32-bit)".
      The name confuses me a little, because my OS (Win7) is 64-bit. And most of my browsers (Palemoon, Waterfox and IE-64bit) are all 64-bit.
      Testing with the settings in the control panel does not solve the problem.
      I have ran the reset_fp11.bat script, which uses the subinacl tool to fix file permissions.
      Taken from this page: https://forums.adobe.com/thread/987370
      This did not solve the problem.
      My user account has administrator privileges.
      I even downloaded the full file: install_flash_player_13_plugin.exe (17.1MB), so I could started it with "Run as administrator".
      Didn't make a difference.
      My question: where are those settings stored ?
      What could be wrong with my setup ?
      How can I fix the problem. How can I troubleshoot. How can I gather more information.
      Thanks in advance,
      Henk.
        • 1. Re: Changes in Adobe Flash Player Settings Manager are not stored
          pwillener Level 8
          This is the Flash Player Settings Manager.  Because that is a 32-bit applet, Windows adds that confusing "(32-bit)" to the name.  Ignore it.
          The settings are stored in various files in
          • %appdata%\Adobe\Flash Player
          • %appdata\Macromedia\Flash Player
          Deleting these two folders should normally fix the problem, but obviously it did not in your case.
          Actually you have done just about everything I can think of.  My best hope is that someone from the Flash Player team will have a look at this topic.
