4 Replies Latest reply on May 21, 2007 11:01 AM by ewriter
    Generating Help from C#
    Wizaerd
      Will this product import and produce documentation for compiled C# assemblies and/or the XML file Visual Studio 2005 generates? I do not want it to parse the project's source code, but to use the actual XML file generated by VS2005...
        • 1. Re: Generating Help from C#
          Wizaerd Level 1
          Can I assume by the lack of responses that it either doesn;t work this way, or nobody knows?
          • 2. Re: Generating Help from C#
            Hi Wizaerd
            I'm guessing you are spot on in your observation!
            Generally speaking, I think you will find this forum to be extremely responsive. It's highly unusual for something to go unaddressed for any lengh of time whatsoever. Normally one of us pounces on it the moment we see it pop in if we have half an answer for you.
            Sorry... Rick
            • 3. Re: Generating Help from C#
              MergeThis Level 4
              If you provided a small sample of the "XML file Visual Studio 2005 generates" we might have some suggestions as to how some additional parsing/mapping by other products could be used. Or not...worth a try, anyway.
              Leon
              • 4. Re: Generating Help from C#
                ewriter Level 1
                I've used lots of xml in RoboHelp and think you have two options here:
                1. Static Output
                RoboHelp 5 allows you to import xml and name an xslt stylesheet for the transform. (there are also some default stylesheets). If done correctly, this import produces a static html page that can then be added and displayed by RH in the usual way.
                2. Dynamic Output
                If you need dynamic display of xml data, you're still going to need a stylesheet, but will also need to create an html page with javascript calls that transform and display the transformed output. (with AJAX, for example). This puts you in the arena of browser detection and using different syntax for different browsers. (there is an additional annoyance of displaying local and server-based output--at least in IE. Firefox doesn't need different syntax). I use this latter approach and construct pages, javascript, etc in an external html editor (Dreamweaver). RH thinks my xml display page is just another html file. It's none the wiser, and, as they say, stuff works. ((javascript, xml, xsl files must be added as baggage files for this to work) You can also look at the Sarissa Library on Sourceforge as a browser agnostic possibility.
                Hope this clarifies your question,
                Andrea
