1. Re: Simulate pressing Enter Key
c.pfaffenbichler May 20, 2014 2:39 AM (in response to Apod42)May I ask what exactly are you trying to achieve?
2. Re: Simulate pressing Enter Key
Apod42 May 20, 2014 2:49 AM (in response to c.pfaffenbichler)Hello,
Using photoshop's script listner I recorded in a .jsx file some print actions. Just before printing I get the warning "The image is larger than the paper's printable area, and some clipping will occur". I do not whis to fix the problem that causes this warning, numerous reasons. I have to click "Proceed" (or hit the Enter key) to continue, No big deal, but when you do this thousands of times it becomes a big deal
My plan:
1. either stop photoshop from showing this warning (or any warnings). - No luck
2. Simulate an enter key hit and proceed with printing
Here is part of the script, the problem appears just below the first block (see my comment):
var id25 = charIDToTypeID( "setd" );
var desc9 = new ActionDescriptor();
var id26 = charIDToTypeID( "null" );
var ref8 = new ActionReference();
var id27 = charIDToTypeID( "Prpr" );
var id28 = stringIDToTypeID( "printOptions" );
ref8.putProperty( id27, id28 );
var id29 = charIDToTypeID( "Dcmn" );
var id30 = charIDToTypeID( "Ordn" );
var id31 = charIDToTypeID( "Trgt" );
ref8.putEnumerated( id29, id30, id31 );
desc9.putReference( id26, ref8 );
var id32 = charIDToTypeID( "T " );
var desc10 = new ActionDescriptor();
var id33 = charIDToTypeID( "PgSt" );
var desc11 = new ActionDescriptor();
var id34 = charIDToTypeID( "Rslt" );
var id35 = charIDToTypeID( "#Pxl" );
desc11.putUnitDouble( id34, id35, 300.000000 );
var id36 = charIDToTypeID( "PgPs" );
var id37 = charIDToTypeID( "PgPs" );
var id38 = stringIDToTypeID( "userDefined" );
desc11.putEnumerated( id36, id37, id38 );
var id39 = charIDToTypeID( "Left" );
var id40 = charIDToTypeID( "#Rlt" );
desc11.putUnitDouble( id39, id40, 0.000000 );
var id41 = charIDToTypeID( "Top " );
var id42 = charIDToTypeID( "#Rlt" );
desc11.putUnitDouble( id41, id42, 1.417323 );
var id43 = charIDToTypeID( "Scl " );
var id44 = charIDToTypeID( "#Prc" );
desc11.putUnitDouble( id43, id44, 100.000000 );
var id45 = charIDToTypeID( "PgSt" );
desc10.putObject( id33, id45, desc11 );
var id46 = charIDToTypeID( "PMps" );
var desc12 = new ActionDescriptor();
var id47 = charIDToTypeID( "PstS" );
desc12.putBoolean( id47, true );
var id48 = charIDToTypeID( "Inte" );
var id49 = charIDToTypeID( "Inte" );
var id50 = charIDToTypeID( "Clrm" );
desc12.putEnumerated( id48, id49, id50 );
var id51 = charIDToTypeID( "SstI" );
desc12.putData( id51, String.fromCharCode( 189, 0, 1, 0, 226, 2, 0, 0, 226, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 181, 33, 0, 0, 213, 23, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 181, 33, 0, 0, 213, 23, 0, 0, 0, 1, 123, 5, 0, 0, 224, 3, 0, 0, 1, 0, 1, 0, 1, 0, 108, 108, 117, 110, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 ) );
var id52 = charIDToTypeID( "PMps" );
desc10.putObject( id46, id52, desc12 );
var id53 = stringIDToTypeID( "printOptions" );
desc9.putObject( id32, id53, desc10 );
executeAction( id25, desc9, DialogModes.NO );
// Here is where the warning pops up. It is here that I need to simulate an enter key hit...
var id54 = charIDToTypeID( "Prnt" );
var desc13 = new ActionDescriptor();
var id55 = charIDToTypeID( "PstS" );
desc13.putBoolean( id55, true );
var id56 = charIDToTypeID( "Inte" );
var id57 = charIDToTypeID( "Inte" );
var id58 = charIDToTypeID( "Clrm" );
desc13.putEnumerated( id56, id57, id58 );
var id59 = charIDToTypeID( "SstI" );
desc13.putData( id59, String.fromCharCode( 189, 0, 1, 0, 226, 2, 0, 0, 226, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 181, 33, 0, 0, 213, 23, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 181, 33, 0, 0, 213, 23, 0, 0, 0, 1, 123, 5, 0, 0, 224, 3, 0, 0, 1, 0, 1, 0, 1, 0, 108, 108, 117, 110, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 ) );
executeAction( id54, desc13, DialogModes.NO );
3. Re: Simulate pressing Enter Key
boo radley 2013 May 27, 2014 10:26 AM (in response to Apod42)I don't know if javascripting can do it, but you can simulate pressing the enter key with another 3rd party application called AutoHotKey - it will do exactly what you want. Check it out, it's easy to find on the web, they have their own huge message forum with thousands of sample scripts, advice, etc.
4. Re: Simulate pressing Enter Key
Apod42 May 27, 2014 11:11 AM (in response to boo radley 2013)Thank you! Will give it a try!
