1. Re: How to adjust caption position in Basic widget
Sanjit_Das May 20, 2014 8:31 AM (in response to brushwipe)Hi Bill
I checked the site , captions are editable in IBE ( In browser editing )
We cannot move the position of object through IBE as this can only be done in design mode.
Please let me know if this is not what you are looking for.
Sanjit
2. Re: How to adjust caption position in Basic widget
brushwipe May 20, 2014 9:48 AM (in response to Sanjit_Das)Hi Sanjit,
Thanks for your attention.
What must I do to give access in design mode? I had hoped you could tell me how to make the changes.
My problem is in positioning the captions to the top left of the image with about 10px padding between each image and its caption which means it must be in a different position for the majority of pages.
I have another twenty images to load but I thought to get it right first.. Problem is that if I set it for the first image it remains the same for position for all other images.
Note the caption position in Just Friends, then see the caption position for First Timer. It doesn't look correct.
Maybe I should use a different slider model? What do you think?
Bill
3. Re: How to adjust caption position in Basic widget
Sanjit_Das May 20, 2014 2:47 PM (in response to brushwipe)Hi Bill
I am little confused with this line " What must I do to give access in design mode?" , as if you want to give access for editing in design mode or if you want to edit the captions in design mode.
Talking about the later one, You can edit the captions in design mode by going to each slideshow.
The caption position would be positioned in same place for all slides by default, we cannot change that differently for separate slides. Looking at your design I would suggest you to use any composition to achieve this.
Insert image as well Text frame in container area and the thumbnails can carry small images, setup autoplay and it would be same effect as slider.
Sanjit
4. Re: How to adjust caption position in Basic widget
brushwipe May 21, 2014 4:49 AM (in response to Sanjit_Das)Thanks Sanjit,
I have studied the Muse Classroom Book more closely and taken a look at the Acrobat files in the DVD that came with the book. It has cleared up my questions.
Thanks for all your help.
Regards
Bill
