3 Replies Latest reply on May 27, 2014 12:28 AM by Willam van Weelden
    Does the fix for WebHelp issues in RoboHelp versions 10 and 11 work when accessing Help from a Web Server?
    MackDuff
      I am using RoboHelp 10 with the latest WebHelp fix.
      I copied the files in the fix to the specified folder in the instructions, regenerated the Help, and tested my WebHelp on IE 8-11.
      When viewed locally, the WebHelp output seems fine.
      The Help is accessed by our users from a web server, so I put up the newly generated output on our web server and tested the output and this is what I found:
      IE 8: Index and Glossary take 3-4 seconds to load, which i guess i okay.
      IE 9: Index and Glossary take 3-4 second to load. Index entries are too big and use a different font.
      IE 10: When you click a topic in the Search pane, you get a blank page. When you click an entry in the Index you get a blank page. After using the Index/Search and then go back to the Contents page, you get a blank page.
      IE 11: Index entries are cut off
      Has anyone else run into these issue? I can live with the issues on IE 8/9/11, but the blank pages on IE 10 are unacceptable. Does the fix not resolve these issues or am I doing something wrong? Why would the fix work locally but not when accessed from a web server?
      Any info would be very much appreciated.
      Mack
