5 Replies Latest reply on May 22, 2014 8:31 AM by hasvi
    empty column
    VeluVK Level 1
      I am doing financial tables, the tables having $, %, ).  I need to align all dollar signs, and % and ) should be hang align, How to fix this type of tables using script. Any script available for this?
      Regards,
      Velu
        • 1. Re: empty column
          Chinnadk Level 4
          Hi Velu,
          Use the below code. Note the position of the tabstop i have given below is '1p' which you can change or fix it in the paragraph style.
          var table = app.activeDocument.stories.everyItem().tables.everyItem().getElements();
          for(i=0; i<table.length; i++){
              var columns = table[i].columns;
              for(var j=0;j<columns.length;j++)
                  if(columns[j].cells[0].contents.indexOf(")") > -1){
                      columns[j].cells.everyItem().texts[0].tabStops.add({position:"1p", alignment:TabStopAlignment.CHARACTER_ALIGN, alignmentCharacter:")"});
                  else if(columns[j].cells[0].contents.indexOf("%") > -1)
                      columns[j].cells.everyItem().texts[0].tabStops.add({position:"1p", alignment:TabStopAlignment.CHARACTER_ALIGN, alignmentCharacter:"%"});
                  else if(columns[j].cells[0].contents.indexOf("$") > -1)
                      columns[j].cells.everyItem().texts[0].tabStops.add({position:"1p", alignment:TabStopAlignment.CHARACTER_ALIGN, alignmentCharacter:"$"});
          Regards,
          Chinna
          • 2. Re: empty column
            VeluVK Level 1
            Hi Chinna,
            Please suggest the below requirement.
            How to fix the financial table using script, (for example see below table. i have fixed manually, my document having more than 50 tables)
            %, ) are hang aligned.
            $  are left aligned as like below.
            Regards,
            Velu
            • 3. Re: empty column
              hasvi Level 1
              Hi velu,
              can you instruct me how to attach the snapshot as like you in this message box
              by
              hasvi
              • 4. Re: empty column
                VeluVK Level 1
                Hi hasvi,
                Click the below icon and insert picture.
                Regards,
                Velu
                • 5. Re: empty column
                  hasvi Level 1
                  Thanks velu
                  Sent from Yahoo Mail on Android
