1 Reply Latest reply: May 21, 2014 12:59 AM by Apod42 RSS
    Close previously opened application
    Apod42 Community Member
      Using Javascript, I do this:
      var file = File('C:/myapplication.exe'); file.execute();
      It opens the application. After I open it, I need it closed. I use this:
      file.close();
      No luck. What am I doing wrong? I use this in a Photoshop script (jsx).
        • 1. Re: Close previously opened application
          Found the solution:
          Not sure which versions are supported but you can
          app.system("Taskkill /F /IM myapplication.exe");
          This is of course windows only. If this does not work you can write Taskkill /F /IM myapplication.exe to a bat file and execute that file.
          var bat = new File("C:/killmyapp.bat"); bat.open("w"); bat.writeln("Taskkill /F /IM myapplication.exe"); bat.close(); bat.execute();
          This is basically same as terminating application from windows task manager.
