1 Reply Latest reply: May 28, 2014 10:39 PM by Ashok Deivasigamani RSS
    need help on submit action when rendering the form as HTML
    Ashok Deivasigamani Community Member
      When FORM is rendered as HTML, the submit button does not work,
      The following are the steps that I performed in my existing XDP form.
      1) Added a button object to the XFA form dom
      2) Gave the following properties to the Submit button in the object pallet
           a) Selected the Contron Type as Execute
           b) Gave a REST end point in the Button property
           c) Selected XDP data package as the submit type
           d) selected UTF-8 as the data encoding type
      3) I rendered the form in the browser (not in the workspace container) but by directly applying the XFAFORMS profile with the url http://localhost:8080/lc/content/xfaforms/profile/default/html?contentRoot=repositor///pat h to the XDP file&template=FileName
      4) When clicking on the submit button on the form, the following error is thrown, please let me know where I am going wrong in the approach to invoke a REST call to the process endpoint
      "Error 500: DSCError: ComponentID= DSC ErrorCode= 122 MinorCode= 0 Message= Input parameter: {2} not found on operation: {0}.{1} ErrorMessage: Input parameter: {2} not found on operation: {0}.{1}"
      Regards -
      Ashok D
        • 1. Re: need help on submit action when rendering the form as HTML
          Guys, the reason that I was not able to submit my form to the process endpoint was because I had designed the process to take an xml as input by the variable name formData, and it seems the REST invocation from the HTML form sends the data as a map of string.
          I changed my process to take a map as the input parameter as input instead of XML and retrieved the form data in the map in the process.
          Steps involved
          1) create a process with a variable of type map of strings as input
          2) create your form and include the http submit button and provide the REST endpoint url as input to the submit button or include a simple button and select the category as submit and provide the needed inputs in the submit tab.
          3) in the process use a execute event and get the value of the input data as a string with the following expression
          map[@data]
          4) Convert the string into XML and use in your process further.
          Regards -
          Ashok D
