3 Replies Latest reply on May 22, 2014 7:53 AM by MrMathType
    mathjax stix font
    Indss
      mathjax stix font is used in mathtype equation file, but when that eps file in placed in InDesign stix font is not embedded in InDesign.
      any suggestion will be helpful...
        • 1. Re: mathjax stix font
          Dov Isaacs Adobe Employee
          When the EPS file is created, is that font being embedded into the EPS? That should solve the problem.
                    - Dov
          • 2. Re: mathjax stix font
            Indss Level 1
            yes the font is not getting embedded in eps. Is it because mathtype does not support the font? but it is been viewed in mathtype.
            • 3. Re: mathjax stix font
              MrMathType Level 3
              The STIX fonts are OTF, which MathType does not fully support. Some of the glyphs within the font will be visible in MT and usable in equations, but the full character set will not be. There may also be other issues, which you've noticed. If you're able to save the equation as PDF rather than EPS, the STIX font symbols should display in ID. (On the Mac, you can save directly as PDF within MathType. If you're on Windows, you can use the Adobe PDF printer. The result should be the same.)
              Bob Mathews
              Design Science
