1. Re: headings of columns in the responses tab
Lucia LaoMay 22, 2014 9:56 AM (in response to sitscj)
Please try to select an earlier version via the History bar in View Responses tab, and see if that helps you recover the headers of the columns.
Related information can be found in this document:
https://forums.adobe.com/docs/DOC-4071
Lucia
2. Re: headings of columns in the responses tab
sitscj May 22, 2014 1:41 PM (in response to Lucia Lao)Thanks for the response, but I can not even find the History bar Will try to enter headings manually and truly hope they will not disappear again...
3. Re: headings of columns in the responses tab
Lucia LaoMay 22, 2014 1:56 PM (in response to sitscj)
Open the form and select "View Responses" tab, on your lower right hand corner, you should see a "clock" icon, click on it, and that should bring up the history bar on the left side. You should be able to click on the any dot shown there to go back in history.
Please take a look at https://forums.adobe.com/docs/DOC-4071 , you should be able to see some screen shots of the history clock icon and the history bar. It is possible that there is only one version of the (new) form, and in this case, there is no history to go back.
Lucia -
4. Re: headings of columns in the responses tab
sitscj May 22, 2014 2:39 PM (in response to sitscj)Thanks!
