6 Replies Latest reply on Jun 3, 2014 3:30 AM by kanaga kumar
    KeyTerm pickup
    kanaga kumar
      Dear Friends,
      I need keyterm definition placed in stub column
      My requirement is:
      1. Multiple keyterms placed in one box
      2. Each keytem placed in each box
      Input file:
      My Requirements:
      1. Multiple Keyterm definition placed in one box
      This is urget requiremnt kindly help me.
      kanaga kumar. k
        • 1. Re: KeyTerm pickup
          kanaga kumar Level 1
          Dear Friends,
          I tried the below mentioned script but it is quit for Indesign. Kindly help in this regard.
          Kindly see my requirement for above:
          var myDoc = app.documents[0];
          var myLib = app.libraries[0];
          app.findTextPreferences = NothingEnum.nothing;
          app.changeTextPreferences = NothingEnum.nothing;
          app.findTextPreferences = null;
          app.findTextPreferences.appliedParagraphStyles= "KTHD" "KTDEF";
          myFind = myDoc.findText(true);
          var myCount=0;
              for (var i=0; i<myFind.length; i++)
                  var myPara = myFind[i].texts[0];
                  myText = myLib.assets.item ("ANNO").placeAsset (myFind[i].insertionPoints[-1])[0];
                  myPara.move(LocationOptions.AT_END, myText.insertionPoints[-1]);
                  myText.appliedObjectStyle = myDoc.objectStyles.item ("Object Styles");
                  myText.fit(FitOptions.frameToContent);
                  myCount++;
          alert(myCount+" ANNOs are Placed Successfully...");
          kanaga kumar.k
          • 2. Re: KeyTerm pickup
            hasvi Level 1
            HI,
            try this one, its may help to you
            app.findTextPreferences.appliedParagraphStyle = "KTHD";
            var
              mFound = app.activeDocument.findText(),
              len = mFound.length,
              currWidth, tarText, tarIP, currFrame, currGB,
              old_VOrigin = app.activeDocument.viewPreferences.verticalMeasurementUnits,
              old_HOrigin = app.activeDocument.viewPreferences.horizontalMeasurementUnits;
            app.activeDocument.viewPreferences.horizontalMeasurementUnits = app.activeDocument.viewPreferences.verticalMeasurementUnits = MeasurementUnits.POINTS;
            while (len-->0) {
              tarText = mFound[len];
              currWidth = tarText.lines[0].endHorizontalOffset - tarText.lines[0].horizontalOffset + 10;
              tarIP = tarText.insertionPoints[-1];
              currFrame = tarIP.textFrames.add();
              setFrame (currFrame);
              currGB = currFrame.geometricBounds;
              currGB = [currGB[0], currGB[3] - currWidth, currGB[2], currGB[3]];
              currFrame.geometricBounds = currGB;
              tarText.texts[0].move(LocationOptions.AFTER,currFrame.texts[0]);
              currFrame.parentStory.characters[-1].remove();
              currFrame.fit(FitOptions.FRAME_TO_CONTENT);
            app.activeDocument.viewPreferences.horizontalMeasurementUnits = old_HOrigin;
            app.activeDocument.viewPreferences.verticalMeasurementUnits = old_VOrigin;
            function setFrame (mAnchored){
              with (mAnchored) {
              anchoredObjectSettings.anchoredPosition = AnchorPosition.ANCHORED;
              anchoredObjectSettings.anchorPoint = AnchorPoint.BOTTOM_RIGHT_ANCHOR;
              anchoredObjectSettings.horizontalReferencePoint = AnchoredRelativeTo.TEXT_FRAME;
              anchoredObjectSettings.verticalReferencePoint = VerticallyRelativeTo.LINE_BASELINE;
              textFramePreferences.insetSpacing = [0,0,0,1];
              textFramePreferences.verticalJustification = VerticalJustification.BOTTOM_ALIGN;
            • 3. Re: KeyTerm pickup
              Jump_Over Level 5
              @ hasvi
              Are you sure it is your code?
              Are you sure it is something new for OP, since it is copied from here:
                   Anchor required
              By the way, threads like this are getting far away from helping. Only goal is "do something instead of me, plssss"
              Jarek
              • 4. Re: KeyTerm pickup
                Dear Friends,
                I have tried to multiple paragraph styles one syntax (bold highlight) but it is quit in indesign. Any one can advice how to give multiple styles (KTHD and KTDEF) in single entry or any other possibility.
                Please correct the below mentioned bold highlight syntax:
                app.findTextPreferences.appliedParagraphStyle= "KTHD" "KTDEF";
                var myCount=0;
                        myCount++;
                kanaga kumar.k
                • 5. Re: KeyTerm pickup
                  Chinnadk Level 4
                  Hi Kanaga Kumar,
                  Try this.
                  var doc = app.activeDocument;
                  var Texts = doc.stories.everyItem().textStyleRanges.everyItem().getElements();
                  for(var i =0;i<Texts.length;i++)
                          if(Texts[i].appliedParagraphStyle == doc.paragraphStyles.item("KTHD"))
                                  if(Texts[i +1].appliedParagraphStyle == doc.paragraphStyles.item("KTDEF"))
                                          var myLibraryItem = app.libraries[0].assets.item("ANNO").placeAsset(Texts[i].insertionPoints[-1])[0];
                                          myLibraryItem.insertionPoints.item(-1).contents  = Texts[i].contents + Texts[i+1].contents;
                                          Texts[i+1].characters.itemByRange(1,-1).remove();
                                          Texts[i].characters.itemByRange(0,-1).remove();
                                          myLibraryItem.insertionPoints.item(0).appliedParagraphStyle = doc.paragraphStyles.item("KTHD");
                  Regards,
                  Chinna
                  • 6. Re: KeyTerm pickup
                    Dear Friend,
                    Thanks for the script, but i have faced some problem. The keyterm ("KTHD") head is not pickup the script. And anchor insertion point is placed in corresponding KT style (megenta rounded box) appear para. Please see below the screen shot.
                    How to fix in automatically adjust height in box and do not need extra entermark (see the screen shot below).
                    kanaga kumar. k
