• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Spambot Form Entry Prevention using CSS & Coldfusion 4.5
New Here ,
May 15, 2007 May 15, 2007
Hello,
I have an html form using a coldfusion post script. I want to create a hidden field using CSS which only spambots will see. Then I need some coldfusion code to tell the form not to submit entries with that field filled in. Is there a good tutorial or site someone knows to explain this for me.
Many Thanks
JD
TOPICS
Advanced techniques
Views
862
Translate
Translate
Report
Report
Community guidelines
community guidelines
Advocate ,
You mean putting 'CAPTCHA' like thing in your page to prevent the SPAM Bots?...
Votes
Translate
Translate
Report
Report
New Here ,
well a CAPTCHA is good but i don't want to give my users more reason not to fill in my form, so a hidden form field that a spambot would naturally fill in without realising is my best bet. any ideas?
Votes
Translate
Translate
Report
Report
Advocate ,
Then add a piece of javascript to check whether the hidden field is filled in with any value or not, and submit the form only if its empty..
Votes
Translate
Translate
Report
Report
New Here ,
do you have an example of some code, i'm not that skilled in javascript. thanks
Votes
Translate
Translate
Report
Report
Advocate ,
like this,
function fnValidate()
if (document.your_form_name.hidden_field_name.value=='')
document.your_form_name.action='your_actionpage.cfm';
document.your_form_name.submit();
and call this function in your <form> tag's onSubmit event like this,
<form name="your_form_name" method="post" onSubmit="return fnValidate();">
Votes
Translate
Translate
Report
Report
New Here ,
hi, thanks for that, i think its worked, fingers crossed for the results and those pesky spambots stop annoying me 🙂
Votes
Translate
Translate
Report
Report
New Here ,
May 16, 2007 May 16, 2007
ok slight problem, whilst the code you gave me was very helpful it seems i need a different fix :
I don't want the spambots to not actually process the form entry, i wish to recieve it but just to a new address spam@hostname.com. By telling the form to process to a new your_actionpage.cfm isn't 100% there. The mail action is obviously controlled by the aplication.cfm which currently can only send to one mailserver. Is there an if comment i can put in the application.cfm which selects variables to send to a different address?
I hope this makes sense. thanks
Votes
Translate
Translate
Report
Report
Advocate ,
Then put some conditions in your <form> tag just infront of the "action" attribute..
For eg.,
Votes
Translate
Translate
Report
Report
Guest
May 17, 2007 May 17, 2007
LATEST
I do it a different way. I create an authorization key that I pass in a hidden form field and save as a session variable. Then upon form submission I check to see if the session auth key matches the form auth key. if not I bounce them somewhere.
Votes
Translate
Translate
Report
Report
Resources
Documentation
