Below are the steps I went through :
. download the installer exe (ColdFusion_11_WWEJ_win.exe) : 571 106 928 octets
. launch it --> nothing happen (I can see in tasklanager some cpu activity during few seconds then nothing)
. then I have tried to open the archive with 7zip and I have found two directories : windows and InstallerData
. then I have tried to execute "windows\adobe_cf.exe" and I got immediatly the message : "Impossible to execute LaunchAnywhere - Error Windows 2 when loading Java VM"
My java version is :
java version "1.7.0_55"
Java(TM) SE Runtime Environment (build 1.7.0_55-b14)
Java HotSpot(TM) Client VM (build 24.55-b03, mixed mode, sharing)
Thank you for your support.
Pierre.
Hi Pierre,
Please try the following Steps :-
1. Launch Command prompt as Administrator.
2. Navigate to the location of ColdFusion 11 installer.
3.Type the command as shown below in the command prompt and press Enter
4. The installer will launch. Please follow the onscreen steps further.
Hope this helps.
Regards,
Anit Kumar
Hi Pierre,
Hope this helps.
Regards,
Anit Kumar
