1 Reply Latest reply on May 22, 2014 3:00 PM by Lucia Lao
    Change footer font color with embedded form?
    noneros
      How do I change the font color on the footer of a form in FormsCentral?
      When I developed the form I was using a design that looked great in a standalone format, but we're considering embedding the form. When I went to embed the form, the links at the bottom became useless because the font in the footer is white (see attached screen shots).
        • 1. Re: Change footer font color with embedded form?
          Lucia Lao Employee Moderator
            In order to see the background color of the form, you will have to enable it.
          Open the form in FormsCentral, go to Distribute tab / Embed sub tab and check : "Include page background color" check box.
          You will need to change the text color of your form header.  Open the form in FormsCentral, select Design Tab, select the form header, select the text and change the text color to other-than-white via the Toolbar.
          Hope this works for you,
          Lucia
