2 Replies Latest reply on May 27, 2014 8:49 AM by Allta Media
    Is there an easy way to duplicate a form and change the field names at once instead of change each field individually?
      I create large adobe files sometimes over 1000 pages.  I have a form I'm required to fill out and attach to the original document that identifies and list the page numbers where various sections can be found.  Unfortunately I need to use the same form sometimes up to 6 times to identify different sections and cannot attach the subsequent forms to the document unless I rename the form fields.  The form has over 100 field to complete so renaming becomes very time consuming.  Is There a quick way that I can add a suffix or prefix to the original form field names to make the same form uniquely different?  I thought using form central to create a form template might be the answer but after going thru the tutorials I'm not understanding how to duplicate a form resulting with a new form with field names different.
