3 Replies Latest reply on May 23, 2014 1:57 PM by Muppet Mark
    Does file.rename() require the file to be open on apple platform?
    knoseworthy
      The Following is for users to be able to pick a csv file , and rename images in a directory based on contents in the csv.
      But file.rename() fails on apple platform but on windows it works without files open.
      var textFile = File.openDialog ("Open Data Excel Sheet", "*.txt,*.csv",false);
      var imageDir = Folder.selectDialog("Select Source Directory");
      var destinationDir = Folder.selectDialog("Select Destination");
      var line = 0;
      var articleColumn = 7;
      var upcColumn= 9;
      var filetype = "*.tif";
      var upctoart = [];
      if(textFile != null && imageDir != null && destinationDir != null){
      textFile.open('r');
      while(!textFile.eof)
      var row = textFile.readln();
      var cols = row.split("\t");
      upctoart[cols[upcColumn]]=cols[articleColumn];
      line++;
      textFile.close();
      var files = imageDir.getFiles(filetype);
      for(var i = 0; i < files.length; i++)
      //alert (files[i].fullName);
      var f = files[i];
      var fileName = f.name;
      var fs = fileName.split("_");
      if(typeof upctoart[fs[0]] == 'undefined')
      continue;
      var artNum = upctoart[fs[0]];
      var destinationFileName = fileName.replace(fs[0],artNum);
      f.rename(destinationDir.fsName + '/' + destinationFileName);
      alert('Done');
