4 Replies Latest reply on May 26, 2014 1:17 PM by MatLac
    Date format
    MatLac Level 3
      My goal is to let the user input time as he pleases but then force an hour format of HH:MM.  I believe the best way to acheive this is use a custom keystroke allowing only numbers with a regex ( since the number format won't allow a leading "0" or a ":") and then use a blur script to take the value and turn it to a Date object of the desired format.  I can't get to turn my string into a Date Time object.
      value is 0545 (for 05:45)
      if (event.target.value != ""){
      var cDate = event.target.valueAsString;
      console.println(cDate)
      var xDate = util.scand("HHMM", cDate)
      console.println(xDate)
      result is:
      Sat Jan 01 2000 00:00:00 GMT-0500 (Est)
      I read through the JS object reference, also this tutorial from Thom Parker, W3, google.....can't find how to take a string from a field and turn it to time.
        • 1. Re: Date format
          You can't use only the time to create a Date object using scand. It's simply not enough information.
          However, what do you need scand for? All you really want to do, it seems, is stick a colon in the middle, no? For that you don't need a Date object.
          • 2. Re: Date format
            MatLac Level 3
            Well, I was hoping turning it to a Date object would at the same time validate its format without having to script a complexe regex for time.  I would have rejected a null object.
            The time format from format tab doesn't allow HHMM, only HH:MM.
            But basically, yes, I just want to force a colon while the user will enter only numbers.  Should I use a combination of keystroke for number and regex for validation or is there a simpler way?
            • 3. Re: Date format
              I've developed for you the following scripts for validating and formatting this value. It's also possible to use a custom keystroke script to only allow numbers to be entered to the field.
              Custom Format script:
              if (event.value)
                  event.value = event.value.substring(0,2) + ":" + event.value.substring(2);
              Custom Validation script:
              if (event.value) {
                  if (/^\d{4}$/.test(event.value)==false) {
                      app.alert("Invalid time value.");
                      event.rc = false;
                  } else {
                      var d = util.scand("mm-dd-yyyy HH:MM", "01-01-2014 " + event.value.substring(0,2) + ":" + event.value.substring(2));
                      if (d==null) {
                          event.rc = false;
                      } else {
                          event.rc = true;
              • 4. Re: Date format
                MatLac Level 3
                works like a charm and so much simpler than what I expected
