4 Replies Latest reply on May 26, 2014 8:19 AM by Steve836
    CPU & Graphics for AE?
    Steve836 Level 1
      Two questions, please.
      I need a new PC for After Effects CS5 (I have no plans to upgrade, so don’t need to factor that in).
      I’m getting 16gb RAM and a cheap graphics card – either Nvidia GT610 or GT640.
      1. With 16gb, will an AMD 8 core give significant benefits over an AMD 6 core, please?
      2. Is there any benefit in spending a little more on a GT640 or will the 610 suffice, please?
      Thanks in advance for any advice,
      Steve
        • 1. Re: CPU & Graphics for AE?
          No. Simply do the math: 16GB/8=2GB per core, 16GB/6=~2.65 GB per core, assuming you were to use all of them just for AE with MP rendering. A marginal difference at best and then of course the usual "if you use feature X, it will nmot use MP rendering..." disclaimers apply.
          Zero. CS5 did not use anything beyond basic OpenGL. Any such decision would be much more dependent on third-party plug-ins that may use GPU-acceleration.
          Mylenium
          • 2. Re: CPU & Graphics for AE?
            Steve836 Level 1
            Hi Mylenium,
            Thanks for the info.
            However, I did a different math - 8 cores at 4.0 ghz each is better than 6 cores at 3.9 ghz.
            Are you saying that CPU power doesn't matter? That RAM is the only thing to be concerned with?
            If so, am I better getting 4 cores so they have 4gb RAM each, or even 2 cores with 8gb?
            Sorry this is such a basic question, but I really have no idea about this subject.
            Steve
            • 3. Re: CPU & Graphics for AE?
              Andrew Yoole MVP & Adobe Community Professional
              Mylenium replied to the option you gave him - you didn't mention clock speed.
              CPU is the most important factor to After Effects (so long as the CPUs have enough RAM).  So, of course 8 x 4.0Ghz cores will render faster than 6 x 3.9 Ghz cores.
              16Gb of RAM in an 8 core machine is not ideal, but will generally perform well.  If you're working on a memory intensive project you can always reduce the number of cores utilised temporarily.
              If this purchase is meant to last you a few years, I'd go with the 8 core machine, but make sure your RAM is configured appropriately (with some free slots) so you can add 8 or 16Gb extra when your budget allows.
              • 4. Re: CPU & Graphics for AE?
                Steve836 Level 1
                Hi Andrew,
                Thanks for elaborating on the CPU issue.
                If renders fail due to memory issues, are you saying I may be able to simply reduce the number of cores to, for example,  4, so they each have 4gb RAM instead of only 2, to get around the issue?
                I hope I've read that right because it's really interesting and something I'd never thought of.
                Steve
