1 Reply Latest reply on May 26, 2014 11:09 AM by ~Sid~
    Form with side by side content area and content flowed.
    rajeshprpc
      Hi I have issue with the logic below,
      i have a master page with 3 content area, 1 at the top header and other 2 side by side below the header. My requirement is like Header content may increase, in such case, the excess left content area should fill in right content area.
      Filling the content works prefectly, but the problem is the right side content gets overlapped with the header text, this is not the case with left side content.
      Could anyone help me on this.
      Also please suggest me if any alternate way to do this.
      Below is the image
        • 1. Re: Form with side by side content area and content flowed.
          ~Sid~ Level 2
          Are the left and right text areas, wrapped within subforms ?
          From what i understand, when your header expands, the left side content is pushed further below. This is only possible if the header and the left area are within flowable subforms.
          Check the pagination properties of the right side subform, you might need to make that, or it's parent container as a flowable subform, in order to be pushed down by header's content.
