This content has been marked as final.
Show 4 replies
1. Re: will i need to have streaming server
RoboWizard May 19, 2007 6:23 AM (in response to Newsgroup_User)Hi Kenny
Streaming server should not be needed here. RoboHelp output lives quite happily on standard, run of the mill web servers. Captivate does seem to dovetail nicely into RoboHelp content. I do it all the time myself, as I actually use RoboHelp as well as Captivate to conduct classes on each!
The only way any form of "streaming" sever would be required would be if you were wanting to utilize Captivate to deliver actual video content in the form of .FLV files. When you do this, there is an option to stream the video.
Hopefully this helps... Rick -
2. Re: will i need to have streaming server
johndaigle May 19, 2007 10:31 AM (in response to RoboWizard)Hi, Twocans
Rick is right on. If I could expand a bit in case others are lurking with similar questions. One of the great things about Adobe Captivate is that the Flash player is so common in all web browsers these days, most everyone can view them quite easily. More and more authors are using camcorder video to illustrate real life situations to users and not just talking heads.
The Flash Video format (FLV) is now supported by Adobe Captivate and Adobe RoboHelp. This is where the Flash Streaming Server Rick referred to may be involved. Fortunately in most cases I've not found it necessary. You can just include your Captivate movie (with or without FLV) into your RoboHelp project and publish to your webserver. If you are using FLV, you would want to add the file to the Baggage virtual folder.. If you have a bunch of FLV video and this is a major part of your project, then it might be worth the extra investment to host them on a Flash Streaming Server (your own, or a hosted server).
Meanwhile, if you'd like to read more about ways to include movies into RoboHelp projects, check out my article on the Adobe Developer Center.
Adobe RoboHelp 6 costars with Adobe Captivate 2
While, you're there, check out the many other articles by Rick Stone, Peter Grainge, Craig Clarke and Matthew Ellison.
The developer center is one of Adobe's best kept secrets. I'm surprised many folks simply don't know about it.
Thanx,
john -
3. Re: will i need to have streaming server
Newsgroup_User May 19, 2007 11:51 AM (in response to RoboWizard)Thanks you very much
gratefully appreciated
Kenny
"johndaigle" <john@johndaigle.com> wrote in message
news:f2ncae$sa5$1@forums.macromedia.com...
> Hi, Twocans
> the
> can
> just
> project
> the
> this
> investment
> http://www.adobe.com/devnet/captivate/articles/cp_rh_integration.html
> Peter
> many
> Thanx,
> john
4. Re: will i need to have streaming server
Newsgroup_User May 19, 2007 11:51 AM (in response to Newsgroup_User)Thanks you very much
Kenny
"RoboWizard" <rstone75@kc.rr.com> wrote in message
news:f2mtnr$ce0$1@forums.macromedia.com...
> Hi Kenny
> you
> form
