2 Replies Latest reply on May 18, 2007 12:48 PM by schmidtjra
    chopping text off a string
    chopTheWood Level 1
      &theVariable= I want to be able to eliminate the first 13 characters of this string so that I just have these two sentences. Is there a way to identify the first n chars, then , set the string equal to what's left over?
        • 1. Re: chopping text off a string
          yes, the flash string methods should be able to handle whatever it is that you want to do. i'm not sure what you want to do, but i'm sure the methods are adequate for the task.
          in particular, the substr() and/or substring() methods should be helpful.
          • 2. Re: chopping text off a string
            schmidtjra
            Taken from AS3 Manual:
            Finding a substring by character position
            The substr() and substring() methods are similar. Both return a substring of a string.
            Both take two parameters. In both methods, the first parameter is the position of the starting
            character in the given string. However, in the substr() method, the second parameter is the
            length of the substring to return, and in the substring() method, the second parameter is
            the position of the character at the end of the substring (which is not included in the returned
            string). This example shows the difference between these two methods:
            var str:String = "Hello from Paris, Texas!!!";
            trace(str.substr(11,15)); // Paris, Texas!!!
            trace(str.substring(11,15)); // output: Pari
            Finding substrings and patterns in strings 215
            The slice() method functions similarly to the substring() method. When given two nonnegative
            integers as parameters, it works exactly the same. However, the slice() method can
            take negative integers as parameters, in which case the character position is taken from the end
            of the string, as shown in the following example:
            trace(str.slice(11,15)); // Pari
            trace(str.slice(-3,-1)); // !!
            trace(str.slice(-3,26)); // !!!
            trace(str.slice(-3,str.length)); // !!!
            trace(str.slice(-8,-3)); // Texas
            You can combine non-negative and negative integers as the parameters of the slice()
            method.
            Finding the character position of a matching
            substring
            You can use the indexOf() and lastIndexOf() methods to locate matching substrings
            within a string, as the following example shows:
            var str:String = "The moon, the stars, the sea, the land";
            trace(str.indexOf("the")); // 10
            Notice that the indexOf() method is case-sensitive.
            You can specify a second parameter to indicate the index position in the string from which to
            start the search, as follows:
            trace(str.indexOf("the", 11)); // 21
            The lastIndexOf() method finds the last occurrence of a substring in the string:
            trace(str.lastIndexOf("the")); // 30
            If you include a second parameter with the lastIndexOf() method, the search is conducted
            from that index position in the string working backward (from right to left):
            trace(str.lastIndexOf("the", 29)); // 21
