1. Re: why does the illustrator cc revert fonts back to myriad pro
BernardM1955 Sep 7, 2014 12:36 PM (in response to Hei-Marie)I have the exact same problem. I hope someone can help us find a solution...
2. Re: why does the illustrator cc revert fonts back to myriad pro
Jacob Bugge Sep 7, 2014 1:26 PM (in response to Hei-Marie)Marie, Bernard,
What happens if you save to PDF and use that or send that to the printer?
3. Re: why does the illustrator cc revert fonts back to myriad pro
BernardM1955 Sep 8, 2014 9:32 AM (in response to Jacob Bugge)Well, in my case, if I copy a piece of text in a certain file A to a file B, then save and close file B, when I return to file, the piece of text I just copied reverts to Myriad Pro right there in my face without me doing anything. It took a while for me to notice the fact, and since this file A is some kind of a reference for many text pieces, it was totally messed up.
Now, I just undo with crtl-z everytime I use something in that A file.
I'm really bothered by that bug...
4. Re: why does the illustrator cc revert fonts back to myriad pro
Monika Gause Sep 8, 2014 9:57 AM (in response to BernardM1955)Is Suitcase installed? Or any other Font manager?
5. Re: why does the illustrator cc revert fonts back to myriad pro
BernardM1955 Sep 8, 2014 12:29 PM (in response to Monika Gause)Mac OS 10.9.4 with latest Creative Cloud
No Suitcase or any font manager installed apart from the Mac OS font manager
Thanks for any help
6. Re: why does the illustrator cc revert fonts back to myriad pro
Jacob Bugge Sep 8, 2014 12:44 PM (in response to BernardM1955)Bernard,
There is no strange EULA issue with Garamond, preventing your use of it?
7. Re: why does the illustrator cc revert fonts back to myriad pro
BernardM1955 Sep 8, 2014 1:03 PM (in response to Jacob Bugge)Sorry, I have no idea of what you are referring to by EULA. And I dont use Garamond, those text elements are in Times New Roman, Symbol and MT Extra...
8. Re: why does the illustrator cc revert fonts back to myriad pro
Jacob Bugge Sep 8, 2014 1:13 PM (in response to BernardM1955)Sorry, Bernard.
I was looking at the OP.
9. Re: why does the illustrator cc revert fonts back to myriad pro
Larry G. Schneider Sep 8, 2014 1:34 PM (in response to BernardM1955)Are the fonts embedded correctly in the file when saving?
10. Re: why does the illustrator cc revert fonts back to myriad pro
BernardM1955 Sep 8, 2014 1:51 PM (in response to Larry G. Schneider)To be honest, this file was created a long time ago as a receptacle for text elements I use in my drawings. Every time I update to a new release of Illustrator, I make sure this file is saved in the newest format. Concerning the fonts, I never used any special option and this problem started with Illustrator CC (2014).
But then again, tell me where I should take a look to checkout what you are referring to.
11. Re: why does the illustrator cc revert fonts back to myriad pro
Larry G. Schneider Sep 8, 2014 2:38 PM (in response to BernardM1955)When you resave the file do you set the top option in the AI Save Options (Fonts:) to 0% which will force the complete font to be embedded in the file?
12. Re: why does the illustrator cc revert fonts back to myriad pro
BernardM1955 Sep 8, 2014 2:45 PM (in response to Larry G. Schneider)Just tried that, problem is still there...
13. Re: why does the illustrator cc revert fonts back to myriad pro
Larry G. Schneider Sep 8, 2014 2:50 PM (in response to BernardM1955)If you do a Find Font on the file are any of the Document Fonts listed with [ ] or < >?
15. Re: why does the illustrator cc revert fonts back to myriad pro
Larry G. Schneider Sep 8, 2014 3:09 PM (in response to BernardM1955)What does the little i symbol indicate if you click on it?
17. Re: why does the illustrator cc revert fonts back to myriad pro
Larry G. Schneider Sep 8, 2014 3:23 PM (in response to BernardM1955)These are the only two reports of this happening so I'm not sure what to say. It's as though AI thinks it is opening a new file.
18. Re: why does the illustrator cc revert fonts back to myriad pro
BernardM1955 Sep 8, 2014 3:29 PM (in response to Larry G. Schneider)Not really. I did a search yesterday and found many posts reporting the same kind of problem. Here are 3 examples, I found more...
Re: Serious problems with text in Illustrator CC 17.1
19. Re: why does the illustrator cc revert fonts back to myriad pro
A-A Sep 9, 2014 8:11 AM (in response to Hei-Marie)I have the same problem with saving out to PNG; some but not all fonts change to Myriad Pro. It's fine when saving out a JPG and PDF.
20. Re: why does the illustrator cc revert fonts back to myriad pro
WMLHLC Dec 2, 2014 10:13 AM (in response to Larry G. Schneider)I have several designers who are experiencing the same issue with Illustrator CC 2014. I can't seem to find any pattern.
