1. Re: Using expand appearance option
Monika Gause May 26, 2014 1:30 AM (in response to brushwipe)Please link the tutorial. Please show a screenshot of what you expect and what instead happens.
Control-F places the content of the clipboard in front of what's selected. If nothing is selected, it places in front.
Control-J joins paths.
There are a lot of expand commands in Illustrator, which one to take depends on the situation. If an effect is applied, Expand appearance should do the job.
You should mind that not every tutorial on the Internet is written by someone who actually knows more than you do.
2. Re: Using expand appearance option
Jacob Bugge May 26, 2014 1:54 AM (in response to brushwipe)brushwipe,
1) as Monika said.
When you expand the inner shape you may as well start by expanding the outer shape and then just use Object>Path>Offset Path and recolour the inner path and be done with it.
If you wish to keep the tutorial mess:
2) the (normal) Selection Tool (black arrow), but there is no need to use it before Object>Expand Appearance because the copy is selected already.
3) When you have clicked Object>Expand Appearance, you should see the double Anchor Points at the rounded corners. If that does not work, and you have followed the step carefully, something is wrong with the preferences or something.
3. Re: Using expand appearance option
brushwipe May 26, 2014 3:41 AM (in response to Monika Gause)Thanks, Sound advice. I have decided to do it all in Photoshop. Life's too short :-)
4. Re: Using expand appearance option
brushwipe May 26, 2014 3:50 AM (in response to Jacob Bugge)Thanks to you and Monica for your time Jacob, After your comments I don't trust this tutorial but I will come back to Illustrator when time permits. I'm carrying on with the buttons in Photoshop.
The tutorial is here in case you are interested:
5. Re: Using expand appearance option
Jacob Bugge May 26, 2014 5:26 AM (in response to brushwipe)For my part you are welcome, brushwipe.
It is quite easy with the help of Illy. You may try it when you get started again.
