22 Replies Latest reply on Apr 6, 2016 1:49 AM by Suzan.V
      • 1. Re: Text wrap bottom offset-by script
        Kasyan Servetsky Level 5
        Here's an example:
        var frame = app.selection[0];
        frame.textWrapPreferences.textWrapOffset = [0, 0, "4 mm", 0];
        • 2. Re: Text wrap bottom offset-by script
          hasvi Level 1
          thanks
          how to get input value of 'textwrap bottom offset'. Because I have to add default 1pica in bottom offset for all the provided indesign file.
          by
          hasvi
          • 3. Re: Text wrap bottom offset-by script
            Harbs. Level 6
            The bottom offset is the third value on the array. The array is top,left,bottom,right.
            • 4. Re: Text wrap bottom offset-by script
              hasvi Level 1
              hi,
              how to find this 'frame.textWrapPreferences.textWrapOffset' throughout indesign files, is this possible by script?
              by
              hasvi
              • 5. Re: Text wrap bottom offset-by script
                Chinnadk Level 4
                Hi Hasvi,
                Try this.
                var txfms =  app.activeDocument.pages.everyItem().textFrames.everyItem().getElements();
                for(var i =0;i<txfms.length;i++)
                        txfms[i].textWrapPreferences.textWrapMode = TextWrapModes.BOUNDING_BOX_TEXT_WRAP;
                        txfms[i].textWrapPreferences.textWrapOffset = [0, 0, "4 mm", 0];
                Regards,
                Chinna
                • 6. Re: Text wrap bottom offset-by script
                  hasvi Level 1
                  Hi Chinna,
                  your script is working for all the textframes in indesign, but I need text wrap adjustment in 'image with caption' text frame only (marked in green color). Please see the snapshot for your reference.
                  First I want to search which page has "text wrap bottom offset in 'image with caption' text frame", Then I want to apply default 4mm bottom offset in 'txfms[i].textWrapPreferences.textWrapMode = TextWrapModes.JUMP_OBJECT_TEXT_WRAP;'Is this possible by script.
                  by
                  hasvi
                  • 7. Re: Text wrap bottom offset-by script
                    hasvi Level 1
                    Hi Chinna,
                    I am going to add default 1pica in 'txfms[i].textWrapPreferences.textWrapOffset = [0, 0, "4 mm(consider this is input value)"+1p(here I want to add default 1p), 0];'. So what is the statement for get input value in below:
                    by
                    hasvi
                    • 8. Re: Text wrap bottom offset-by script
                      Chinnadk Level 4
                      Hi Hasvi,
                      If you want to give textwrapoffset to the frame which has only image caption than put it into a separate layer or give a name to it via script label, then get them into a loop and give textwrapoffset.
                      Use the below code to add 1pica to bottom the offset,
                      var doc =app.activeDocument;
                      var oldhm = doc.viewPreferences.horizontalMeasurementUnits;
                      var oldvm = doc.viewPreferences.verticalMeasurementUnits;
                      doc.viewPreferences.horizontalMeasurementUnits = doc.viewPreferences.verticalMeasurementUnits = MeasurementUnits.picas;
                              var tf = txfms[i].textWrapPreferences.textWrapOffset;
                              txfms[i].textWrapPreferences.textWrapOffset = [0, 0, tf[2] + 1, 0];
                      doc.viewPreferences.horizontalMeasurementUnits = oldhm;
                      doc.viewPreferences.verticalMeasurementUnits = oldvm;
                      Regards,
                      Chinna
                      • 9. Re: Text wrap bottom offset-by script
                        Jump_Over Level 5
                        In case of many various unit operation it could be easier to use unit.convert() method.
                        Example:
                        nValue = new UnitValue(1,"picas");
                        nValue.convert("mm");
                        txfms[i].textWrapPreferences.textWrapOffset = [0, 0, tf[2] + nValue.value, 0];
                        Jarek
                        • 10. Re: Text wrap bottom offset-by script
                          hasvi Level 1
                          Hi Chinna,
                          Its working fine, but below error shows when running, and command is "Object does not support the property or method '2'"
                          hi can you explain me what is "tf[2]" here.
                          by
                          hasvi
                          • 11. Re: Text wrap bottom offset-by script
                            Chinnadk Level 4
                            Re-order the below lines.
                            txfms[i].textWrapPreferences.textWrapOffset = [0, 0, tf[2] + parseFloat("1p"), 0];
                            txfms[i].textWrapPreferences.textWrapOffset returns array of four units [top, left, bottom, right] here tf[0] is top, tf[1] is left, tf[2] is bottom, tf[3] is right.
                            Regards,
                            Chinna
                            • 12. Re: Text wrap bottom offset-by script
                              hasvi Level 1
                              Hi chinna,
                              Thanks for your information, as you said we have follow this in script lable or layer option. Now I have used with script lable, So text wrap option applied for 'image box with caption' and as well as my total 'text frame'.
                              BUt I need text wrap only for 'image box with caption', So is this possible in layer option? pls help
                              by
                              hasvi
                              • 13. Re: Text wrap bottom offset-by script
                                Chinnadk Level 4
                                Hi Hasvi,
                                For accessing via script label replace the below lines in for loop.
                                if(txfms[i].label == "caption")//Give "caption" as a name for all the caption frames via script label
                                For accessing via layers replace the below lines in for loop.
                                if(txfms[i].itemLayer == doc.layers.item("caption"))//create a layer named "caption" and move the caption frame into it
                                Regards,
                                Chinna
                                • 14. Re: Text wrap bottom offset-by script
                                  hasvi Level 1
                                  Hi chinna,
                                  your answers are very very useful for us.
                                  by
                                  hasvi
                                  • 15. Re: Text wrap bottom offset-by script
                                    hasvi Level 1
                                    Hi chinna,
                                    this is the code:
                                    if((globBaseLineDiff!=0) && myTextWrap.textWrapPreferences.textWrapMode = TextWrapModes.BOUNDING_BOX_TEXT_WRAP)
                                                var tf = myTextWrap.textWrapPreferences.textWrapOffset;
                                                myTextWrap.textWrapPreferences.textWrapOffset = [tf[0], tf[1], tf[2]+ globBaseLineDiff, tf[3]];
                                    FYI see snapshot:
                                    Before script:
                                    After script:
                                    I am inserting space in 'Bottom Offset' only, but after running my script 'Top Offset & Left Offset & Right Offset' value getting to 0. Here how to retain my input value in this bold place
                                    by
                                    hasvi
                                    • 16. Re: Text wrap bottom offset-by script
                                      hasvi Level 1
                                      Hi chinna,
                                      Are you there?
                                      by
                                      hasvi
                                      • 17. Re: Text wrap bottom offset-by script
                                        hasvi Level 1
                                        I am using this condition only for "JUMP_OBJECT_TEXT_WRAP"
                                        if((mypageDiff!=0) && (myTextWrap.textWrapPreferences.textWrapMode = TextWrapModes.JUMP_OBJECT_TEXT_WRAP))
                                        but its alpplied for--TextWrapModes.BOUNDING_BOX_TEXT_WRAP also how can we control it?
                                        by
                                        hasvi
                                        • 18. Re: Text wrap bottom offset-by script
                                          Chinnadk Level 4
                                          Hi Hasvi,
                                          Replace '=' with '==' in the 'if' condition and try.
                                          if((mypageDiff!=0) && (myTextWrap.textWrapPreferences.textWrapMode == TextWrapModes.JUMP_OBJECT_TEXT_WRAP))
                                          Regards,
                                          Chinna
                                          • 19. Re: Text wrap bottom offset-by script
                                            hasvi Level 1
                                            Hi chinna,
                                            thanx
                                            by
                                            hasvi
                                            • 20. Re: Text wrap bottom offset-by script
                                              Chinnadk Level 4
                                              Hi Hasvi,
                                              If the answer is correct then mark the answer as correct and close the thread.
                                              Regards,
                                              Chinna
                                              • 21. Re: Text wrap bottom offset-by script
                                                hasvi Level 1
                                                hi chinna sorry for this mix-up
                                                by
                                                havi
                                                • 22. Re: Text wrap bottom offset-by script
                                                  Suzan.V Level 1
                                                  Hi all,
                                                  are there anyway to edit your code to reverse values whatever it is between left offset and right offset as shown
