7 Replies Latest reply on May 31, 2014 9:27 AM by hemanthR
    Corrupted animation with duplicate stage elments.
    HuwL
      My animation seems to have corrupted, duplicating all the stage elements and putting all the actions code into one long single line of code. It runs OK in preview, and if I publish as standard, but if I publish as static html the animation is corrupted with images all over the place and the text doesn't appear in the code.
      Has anyone else experienced this and if so, Is there any way I can clear this corruption and get it back how it should be?
        • 1. Re: Corrupted animation with duplicate stage elments.
          hemanthR Adobe Employee
          Do you  face this problem only when you publish to static HTML?
          Can you mail or post your composition?
          • 2. Re: Corrupted animation with duplicate stage elments.
            HuwL Level 1
            Hi Hemanth,
            Thanks for getting back to me. I tried to send a reply but it was rejected, possibly because I put links to my website in it? Yes the animation only messes up completely when I publish as static html although there are some other odd things about it as mentioned above
            I don't know how to e-mail you stuf, but I've pasted the html code from one of the slideshows below (I have about 30 altogether, about 10 work fine and the rest seem to be 'corrupted'. This is the version which has been published as static html and messes up, you can see the exact same animation only published normally if you go on my website (google my name) and go to the India page.
            I hope this is useful, let me know if you need anything else. (like the java script)
            Hugh Lansdown
            <!DOCTYPE html>
            <html>
            <head>
                <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
                <meta http-equiv="X-UA-Compatible" content="IE=Edge"/>
                <title>India Slideshow</title>
            <!--Adobe Edge Runtime-->
                <script type="text/javascript" charset="utf-8" src="india-slideshow_edgePreload.js"></script>
                <style>
                    .edgeLoad-EDGE-43981328 { visibility:hidden; }
                </style>
            <!--Adobe Edge Runtime End-->
            </head>
            <body style="margin:0;padding:0;">
                <div id="Stage" class="EDGE-43981328">
                    <div id="Stage_play-button-active" class="edgeLoad-EDGE-43981328"></div>
                    <div id="Stage_back-button-active" class="edgeLoad-EDGE-43981328"></div>
                    <div id="Stage_pause-button-active-right" class="edgeLoad-EDGE-43981328"></div>
                    <div id="Stage_pause-button-active-left" class="edgeLoad-EDGE-43981328"></div>
                    <div id="Stage_back-button-inactive" class="edgeLoad-EDGE-43981328"></div>
                    <div id="Stage_pause-button-inactive-right" class="edgeLoad-EDGE-43981328"></div>
                    <div id="Stage_pause-button-inactive-left" class="edgeLoad-EDGE-43981328"></div>
                    <div id="Stage_play-button-inactive" class="edgeLoad-EDGE-43981328"></div>
                    <div id="Stage__10-location" class="edgeLoad-EDGE-43981328">Kruger National Park, South Africa</div>
                    <div id="Stage__10-name" class="edgeLoad-EDGE-43981328">Male Impala (Aepyceros melampus)</div>
                    <div id="Stage__10-rectangle104" class="edgeLoad-EDGE-43981328">
                        <div id="Stage__10-thumbnail100" class="edgeLoad-EDGE-43981328"></div>
                    </div>
                    <div id="Stage__10-main-image650" class="edgeLoad-EDGE-43981328"></div>
                    <div id="Stage__09-location" class="edgeLoad-EDGE-43981328">Kruger National Park, South Africa</div>
                    <div id="Stage__09-name" class="edgeLoad-EDGE-43981328">Greater Blue-eared Starling (L. chalybaeus)</div>
                    <div id="Stage__09-rectangle104" class="edgeLoad-EDGE-43981328">
                        <div id="Stage__09-thumbnail100" class="edgeLoad-EDGE-43981328"></div>
                    </div>
                    <div id="Stage__09-main-image650" class="edgeLoad-EDGE-43981328"></div>
                    <div id="Stage__08-location" class="edgeLoad-EDGE-43981328">Kruger National Park, South Africa</div>
                    <div id="Stage__08-name" class="edgeLoad-EDGE-43981328">Wandering Donkey Acraea (Acraea neobule)</div>
                    <div id="Stage__08-rectangle104" class="edgeLoad-EDGE-43981328">
                        <div id="Stage__08-thumbnail100" class="edgeLoad-EDGE-43981328"></div>
                    </div>
                    <div id="Stage__08-main-image650" class="edgeLoad-EDGE-43981328"></div>
                    <div id="Stage__07-location" class="edgeLoad-EDGE-43981328">Kruger National Park, South Africa</div>
                    <div id="Stage__07-name" class="edgeLoad-EDGE-43981328">Dwarf Mongoose (Helogale parvula)</div>
                    <div id="Stage__07-rectangle104" class="edgeLoad-EDGE-43981328">
                        <div id="Stage__07-thumbnail100" class="edgeLoad-EDGE-43981328"></div>
                    </div>
                    <div id="Stage__07-main-image650" class="edgeLoad-EDGE-43981328"></div>
                    <div id="Stage__06-location" class="edgeLoad-EDGE-43981328">Kruger National Park, South Africa</div>
                    <div id="Stage__06-name" class="edgeLoad-EDGE-43981328">Crested Barbet (Trachyphonus vaillantii)</div>
                    <div id="Stage__06-rectangle104" class="edgeLoad-EDGE-43981328">
                        <div id="Stage__06-thumbnail100" class="edgeLoad-EDGE-43981328"></div>
                    </div>
                    <div id="Stage__06-main-image650" class="edgeLoad-EDGE-43981328"></div>
                    <div id="Stage__05-location" class="edgeLoad-EDGE-43981328">Kruger National Park, South Africa</div>
                    <div id="Stage__05-name" class="edgeLoad-EDGE-43981328">Giraffe drinking (Giraffa camelopardalis)</div>
                    <div id="Stage__05-rectangle104" class="edgeLoad-EDGE-43981328">
                        <div id="Stage__05-thumbnail100" class="edgeLoad-EDGE-43981328"></div>
                    </div>
                    <div id="Stage__05-main-image650" class="edgeLoad-EDGE-43981328"></div>
                    <div id="Stage__04-location" class="edgeLoad-EDGE-43981328">Kruger National Park, South Africa</div>
                    <div id="Stage__04-name" class="edgeLoad-EDGE-43981328">Steenbok (Raphicerus campestris)</div>
                    <div id="Stage__04-rectangle104" class="edgeLoad-EDGE-43981328">
                        <div id="Stage__04-thumbnail100" class="edgeLoad-EDGE-43981328"></div>
                    </div>
                    <div id="Stage__04-main-image650" class="edgeLoad-EDGE-43981328"></div>
                    <div id="Stage__03-location" class="edgeLoad-EDGE-43981328">Kruger National Park, South Africa</div>
                    <div id="Stage__03-name" class="edgeLoad-EDGE-43981328">African Wild Dog (Lycaon pictus)</div>
                    <div id="Stage__03-rectangle104" class="edgeLoad-EDGE-43981328">
                        <div id="Stage__03-thumbnail100" class="edgeLoad-EDGE-43981328"></div>
                    </div>
                    <div id="Stage__03-main-image650" class="edgeLoad-EDGE-43981328"></div>
                    <div id="Stage__02-location" class="edgeLoad-EDGE-43981328">Kruger National Park, South Africa</div>
                    <div id="Stage__02-name" class="edgeLoad-EDGE-43981328">Southern Yellow-billed Hornbill (Tockus leucomelas)</div>
                    <div id="Stage__02-rectangle104" class="edgeLoad-EDGE-43981328">
                        <div id="Stage__02-thumbnail100" class="edgeLoad-EDGE-43981328"></div>
                    </div>
                    <div id="Stage__02-main-image650" class="edgeLoad-EDGE-43981328"></div>
                    <div id="Stage__01-location" class="edgeLoad-EDGE-43981328">Kruger National Park, South Africa</div>
                    <div id="Stage__01-name" class="edgeLoad-EDGE-43981328">Male Burchell's Zebra (Equus burchelli)</div>
                    <div id="Stage__01-rectangle104" class="edgeLoad-EDGE-43981328">
                        <div id="Stage__01-thumbnail100" class="edgeLoad-EDGE-43981328"></div>
                    </div>
                    <div id="Stage__01-main-image650" class="edgeLoad-EDGE-43981328"></div>
                    <div id="Stage__10-location" class="edgeLoad-EDGE-43981328">Vembanad Lake, Kerula, southern India</div>
                    <div id="Stage__10-name" class="edgeLoad-EDGE-43981328">White-throated Kingfisher (H. smyrnensis)</div>
                    </div>
                    <div id="Stage__09-location" class="edgeLoad-EDGE-43981328">Agra Fort, Agra, Northern India</div>
                    <div id="Stage__09-name" class="edgeLoad-EDGE-43981328">Young Rhesus Macaque (Macaca mulatta)</div>
                    </div>
                    <div id="Stage__08-location" class="edgeLoad-EDGE-43981328">Vembanad Lake, Kerula, southern India</div>
                    <div id="Stage__08-name" class="edgeLoad-EDGE-43981328">Little Cormorant (Phalacrocorax niger)</div>
                    </div>
                    <div id="Stage__07-location" class="edgeLoad-EDGE-43981328">Ranthambore National Park, northern India</div>
                    <div id="Stage__07-name" class="edgeLoad-EDGE-43981328">Male Nilgai (Boselaphus tragocamelus)</div>
                    </div>
                    <div id="Stage__06-location" class="edgeLoad-EDGE-43981328">Vembanad Lake, Kerula, southern India</div>
                    <div id="Stage__06-name" class="edgeLoad-EDGE-43981328">Brahminy Kite (Haliastur indus)</div>
                    </div>
                    <div id="Stage__05-location" class="edgeLoad-EDGE-43981328">Ranthambore National Park, northern India</div>
                    <div id="Stage__05-name" class="edgeLoad-EDGE-43981328">Male Sambar Deer (Rusa unicolor)</div>
                    </div>
                    <div id="Stage__04-location" class="edgeLoad-EDGE-43981328">Ranthambore National Park, northern India</div>
                    <div id="Stage__04-name" class="edgeLoad-EDGE-43981328">Northern Plains Gray Langur (S. entellus)</div>
                    </div>
                    <div id="Stage__03-location" class="edgeLoad-EDGE-43981328">Bangalore, southern India</div>
                    <div id="Stage__03-name" class="edgeLoad-EDGE-43981328">Flock of Cattle Egrets (Bubulcus ibis)</div>
                    </div>
                    <div id="Stage__02-location" class="edgeLoad-EDGE-43981328">Ranthambore National Park, northern India</div>
                    <div id="Stage__02-name" class="edgeLoad-EDGE-43981328">Male Spotted Deer (Axis axis)</div>
                    </div>
                    <div id="Stage__01-location" class="edgeLoad-EDGE-43981328">Ranthambore National Park, northern India</div>
                    <div id="Stage__01-name" class="edgeLoad-EDGE-43981328">Tiger (Panthera tigris)</div>
                    </div>
                </div>
            </body>
            </html>
            • 3. Re: Corrupted animation with duplicate stage elments.
              You can upload and share your files on any of the cloud storage service like the Creative Cloud,dropbox etc and  share the link here.
              We have fixed a couple of bugs related to static html for next release.Wanted to test even with your files to see if its the same issue
              • 4. Re: Corrupted animation with duplicate stage elments.
                HuwL Level 1
                Do you want the whole animation, including html, java,an file, images... the lot?
                • 5. Re: Corrupted animation with duplicate stage elments.
                  Better if I can  get the  complete composition.If thats ok with you
                  • 6. Re: Corrupted animation with duplicate stage elments.
                    HuwL Level 1
                    I've copied the whole folder containing the india animation to dropbox here:
                    https://www.dropbox.com/sh/00lednoa8377tcl/AACGkT1r9ZvQBY15Q8nkZRO4a
                    This is the unpublished version that I worked on while I was creating it. It appears to work OK in edge animate and viewed in a browser window but when I publish it to my website with static html it messes up. Can you take a copy so I can delete it from dropbox as I don't want it available to the general public.
                    • 7. Re: Corrupted animation with duplicate stage elments.
                      I have download the composition .Please go ahead and delete it.I do not have permission.
                      Thanks !!
                      This will help us make Animate better.
                      Hemanth
