1. Re: difference between methods of drawing shapes
c.pfaffenbichler May 26, 2014 7:27 AM (in response to stribor-stribor)Selection Tools create pixel Selections, Path Tools create Paths which do practically not lose quality on repeated transformations and Vector Masks can be output as vector content in eps and pdf.
2. Re: difference between methods of drawing shapes
stribor-stribor May 26, 2014 7:34 AM (in response to stribor-stribor)so what would happen if i create circle with selection tool and fill it with color..then save it and then enlarge it?
now when i think about ellipse tool and create circle and fill it with color. I believe it will prompt me to rasterize layer. So my question is how would one create colored logo that can be enlarged or shrink-ed as needed without it losing the quality?
3. Re: difference between methods of drawing shapes
c.pfaffenbichler May 26, 2014 7:37 AM (in response to stribor-stribor)so what would happen if i create circle with selection tool and fill it with color..then save it and then enlarge it?
It has to be interpolated and that may, depending on the transformation, result is a noticeably bad quality of the edge.
Create Paths and use them as Vector Masks on Solid Color/Shape Layers.
Or do it in Illustrator or another vector oriented program.
4. Re: difference between methods of drawing shapes
stribor-stribor May 26, 2014 7:45 AM (in response to stribor-stribor)so if you dont care about output you can use pixel tools or vector tools regardless
5. Re: difference between methods of drawing shapes
JJMack May 26, 2014 7:47 AM (in response to stribor-stribor)The Ellipse tool can create paths, colpr pixels as well as shape layer. A shape layer contains the ellipse Path. The shape Path can be stroked with many styles of stroke and alignments and if the path is a closed path it can be filled with a color or pattern or left empty. If you re-size the layer or document you will not be asked to rasterize a shape layer. Shape will be resized using vector graphics. Shape layers can also have layer style added.
6. Re: difference between methods of drawing shapes
JJMack May 26, 2014 7:52 AM (in response to stribor-stribor)stribor-stribor wrote:
If you don't care about your results why use Photoshop? Its expensive...
7. Re: difference between methods of drawing shapes
c.pfaffenbichler May 26, 2014 7:57 AM (in response to stribor-stribor)so if you dont care about output you can use pixel tools or vector tools regardless
Certainly, it’s each users own decision how much thought and foresight they want to put into a project.
But maybe you should consider that some customers may consider everything they have omitted to specify (like that a product will be used at much larger sizes later on) to be implied and may be unwilling to take responsibility for causing unnecessary work.
8. Re: difference between methods of drawing shapes
stribor-stribor May 26, 2014 8:10 AM (in response to stribor-stribor)actually what i am doing is just learning it and not using it to show customer. I wanted to know why i would use 2 different tools. At this level right now all i want to is produce circle on the screen that might have stroke and fill:)
9. Re: difference between methods of drawing shapes
JJMack May 26, 2014 1:06 PM (in response to stribor-stribor)Use the right tool for the job at hand. There are many way to do things some ways are better the others. One does not learn Photoshop overnight.
