3 Replies Latest reply on May 27, 2014 9:53 AM by Sebastian.Toro
    Flex's HTTPService dispatches a ResultEvent instead of a FaultEvent
    Sebastian.Toro Level 1
      I would like to know when does Flex's HTTPService launches a ResultEvent and when does it dispatches a FaultEvent.
      When the servers response contain a 401 http status code error (Unauthorized), the HTTPService is dispatches a ResultEvent instead of a FaultEvent. I would assume that it should dispatch a FaultEvent. Am I correct? If not please tell me.
      The amazing thing is that when I'm running the application under the Flash Builder 4.7's Android Simulator, it does dispatch a FaultEvent, but when I run it on the device, it dispatches the ResultEvent. Why is this happening? Any ideas?
        • 1. Re: Flex's HTTPService dispatches a ResultEvent instead of a FaultEvent
          zassadgh
          FaultEvent is only fired when the http status error is not in the collection or unknown.
          if you get an error 201 or some that is not in the error code collection, you could get the returned content by event.fault.content, if there is any.
          the Flash Builder 4.7's Android Simulator might use another AIR version then the device.
          • 2. Re: Flex's HTTPService dispatches a ResultEvent instead of a FaultEvent
            Hi zassadgh,
            Thanks for your answer, though I think its not the right one. The most common HTTP status codes are familiar to the Flex SDK and it has no problem identifying them. On the next hour I'll post the results of a detailed test regarding the matter, so people can comment them.
            And as a matter of fact, you are correct, both AIR versions are different. I'll try to run the same test on the same AIR versions.
            Thanks again.
            • 3. Re: Flex's HTTPService dispatches a ResultEvent instead of a FaultEvent
              I created an application to test what happens on both scenarios (Flash Builder's Simulator and Android Device) and compare the results. Next is the code.
              Test application code
              <s:View xmlns:fx="http://ns.adobe.com/mxml/2009"
              xmlns:s="library://ns.adobe.com/flex/spark" title="HomeView">
              <fx:Script>
                <![CDATA[
                import mx.rpc.events.FaultEvent;
                import mx.rpc.events.ResultEvent;
                ///////////////////////////// USING HIGH LEVEL COMPONENT (FLEX) //////////////////////////////////////////
                * Checks if all the necesary data was entered by the user.
                protected function configHandler(event:MouseEvent):void
                textArea.text = "Connecting to server using a high level component";
                configurationService.url = "http://10.0.0.221/api/v1/room/current/";
                configurationService.headers.Accept = "application/json";
                configurationService.send();
                textArea.appendText("\n...");
                * Handles the first phase (getting basic application information) of the configuration.
                * Stores the retrieved data from the server and calls the second phase of the process.
                protected function serviceResultHandler(event:ResultEvent):void
                textArea.appendText("\n");
                textArea.appendText("Entering serviceResultHandler \n");
                textArea.appendText(" HTTP status code is: " + event.statusCode);
                * Handles errors within the first phase (getting basic application information) of the configuration process.
                protected function servicefaultHandler(event:FaultEvent):void
                textArea.appendText("Entering servicefaultHandler \n");
                textArea.appendText("HTTP status code is: " + event.statusCode);
                ///////////////////////////// USING LOW LEVEL COMPONENT (FLASH) //////////////////////////////////////////
                protected function config2Handler(event:MouseEvent):void
                textArea.text = "Connecting to server using a low level component \n ...";
                var loader:URLLoader = new URLLoader();
                var request:URLRequest = new URLRequest("http://10.0.0.221/api/v1/room/current/");
                request.requestHeaders = new Array( new URLRequestHeader('Accept','application/json'));
                try {
                loader.load(request);
                } catch (error:Error) {
                trace("Unable to load requested document.");
                loader.addEventListener(Event.COMPLETE, completeHandler);
                loader.addEventListener(Event.OPEN, openHandler);
                loader.addEventListener(ProgressEvent.PROGRESS, progressHandler);
                loader.addEventListener(SecurityErrorEvent.SECURITY_ERROR, securityErrorHandler);
                loader.addEventListener(HTTPStatusEvent.HTTP_STATUS, httpStatusHandler);
                loader.addEventListener(IOErrorEvent.IO_ERROR, ioErrorHandler);
                private function completeHandler(event:Event):void {
                var loader:URLLoader = URLLoader(event.target);
                textArea.appendText("Entering completeHandler \n");
                textArea.appendText("completeHandler: " + loader.data + "\n");
                var vars:URLVariables = new URLVariables(loader.data);
                textArea.appendText("The answer is " + vars.answer);
                private function openHandler(event:Event):void {
                textArea.appendText("Entering openHandler \n");
                textArea.appendText("openHandler: " + event);
                private function progressHandler(event:ProgressEvent):void {
                textArea.appendText("Entering progressHandler \n");
                textArea.appendText("progressHandler loaded:" + event.bytesLoaded + " total: " + event.bytesTotal);
                private function securityErrorHandler(event:SecurityErrorEvent):void {
                textArea.appendText("Entering securityErrorHandler \n");
                textArea.appendText("securityErrorHandler: " + event);
                private function httpStatusHandler(event:HTTPStatusEvent):void {
                textArea.appendText("Entering httpStatusHandler \n");
                textArea.appendText("httpStatusHandler: " + event);
                private function ioErrorHandler(event:IOErrorEvent):void {
                textArea.appendText("Entering ioErrorHandler \n");
                textArea.appendText("ioErrorHandler: " + event);
              </fx:Script>
              <fx:Declarations>
              <s:HTTPService id="configurationService"
              result="serviceResultHandler(event)" fault="servicefaultHandler(event)"/>
              </fx:Declarations>
              <s:Button label="High Level" click="configHandler(event)"
              horizontalCenter="100" top="20" />
              <s:Button label="Low Level" click="config2Handler(event)"
              horizontalCenter="-100" top="20"/>
              <s:TextArea id="textArea"
              left="20" right="20" top="{configButton.y + configButton.height + 20}" bottom="20"/>
              </s:View>
              Results on the Flash Builder Simulator
              • When pressing the "Low Level" button (URL Loader) the text on the text area was:
                Connecting to server using a low level component ... Entering openHandler openHandler: [Event type="open" bubbles=false cancelable=false eventPhase=2] Entering httpStatusHandler httpStatusHandler: [HTTPStatusEvent type="httpStatus" bubbles=false cancelable=false eventPhase=2  status=401 responseURL=null] Entering ioErrorHandler ioErrorHandler: [IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2032: Stream Error. URL: http://10.0.0.221/api/v1/room/current/" errorID=2032]
              • When pressing the "High Level" button (HTTPService) the text on the text area was:
                Connecting to server using a high level component ... Entering servicefaultHandler HTTP status code is: 401
              Results on the Android device
                Connecting to server using a low level component ... Entering openHandler openHandler: [Event type="open" bubbles=false cancelable=false eventPhase=2] Entering httpStatusHandler httpStatusHandler: [HTTPStatusEvent type="httpStatus" bubbles=false cancelable=false eventPhase=2  status=401 redirected=false responseURL=null] Entering completeHandler completeHandler:
                Connecting to server using a high level component ... Entering serviceResultHandler HTTP status code is: 401
              When I ran the app on the Flash Builder's Simulator, both components worked as expected, meaning that they dispatched a FaultEvent and an IOErrorEvent. On the Android device each component misbehaived, the first dispatching a ResultEvent and the second one an Event.COMPLETE event.
              Notice that on both scenarios, both components percieve the correct HTTP status code.
              I would assume that there is a problem with the runtime, right? I'd appreciate your comments on the matter.
