2 Replies Latest reply on May 26, 2014 5:07 PM by JesseHarris
    AE CC Importing Multiple JPEGS As A Sequence/MOV
    JesseHarris Level 1
      Hi - I've just upgraded from AE CS6 to CC on a 2013 MBP with OS 10.8.4
      I usually import raw files for time lapse work, for this sequence however I've captured jpegs.  Command-I for the import window and I've chosen ALL ACCEPTABLE FILES, formate JPEG and checked SEQUENCE.  The problem is that when I select ALL the jpegs in the folder the SEQUENCE check box disappears and MULTIPLE SEQUENCES is the check box...
      Also the FOOTAGE pulldown is grayed out.
      I want to import the jpegs as footage but they import as individual files!
      How do I make the jpegs a JPEG Sequence or Footage/mov?
      Thank you
