12 Replies Latest reply on May 22, 2007 7:21 AM by padrepio
    AS 3.0 Loading external text from a text file
    padrepio Level 1
      OK, so things have changed, a lot. In AS 2.0, I could create a text or HTML file with variables and have dynamic text fields to display the text from the loadVariablesNum argument. AS 3.0 uses a totally different model. How can I simply grab text from an external document and display it in a dynamic text field?
        • 1. Re: AS 3.0 Loading external text from a text file
          Level 7
          padrepio,
          Between AS2 and 3? Yes. :)
          loadVariablesNum() is a function, actually, and is similar to
          loadVariables(). There's also the LoadVars class, whose methods comprise
          similar functionality yet again.
          > text field?
          Here's a quick sample snippet.
          // Instantiate the URLLoader class
          var loader:URLLoader = new URLLoader();
          // Set the URLLoader's dataFormat property
          // to the static constant shown
          loader.dataFormat = URLLoaderDataFormat.VARIABLES;
          // Load the text file, making sure the path
          // itself is an instance of URLRequest
          loader.load(new URLRequest("data.txt"));
          That's it, really. Just three lines, so it's really not so bad. :)
          The data.txt reference show contains the following string:
          a=apples&b=bears&c=carrots
          To use the data as they become available, handle a complete event for
          that URLLoader instance ...
          loader.addEventListener(
          Event.COMPLETE,
          function(evt:Event):void {
          trace(evt.target.data.a);
          trace(evt.target.data.b);
          trace(evt.target.data.c);
          Note that the incoming parameter of the function literal (an arbitrary
          "evt") is an object that contains a target property. That target property
          refers back to the loader (URLLoader) instance, which in turn has a data
          property. The data property contains the three variables noted in the same
          text file.
          David Stiller
          Adobe Community Expert
          Dev blog, http://www.quip.net/blog/
          "Luck is the residue of good design."
          • 2. Re: AS 3.0 Loading external text from a text file
            Level 7
            Take a look at:
            http://www.kirupa.com/forum/showthread.php?p=1910480#post1910480
            "padrepio" <webforumsuser@macromedia.com> wrote in message
            news:f2k5o8$1pv$1@forums.macromedia.com...
            > HTML
            > the
            > I
            > text
            > field?
            • 3. Re: AS 3.0 Loading external text from a text file
              padrepio Level 1
              OK, that's making a little more sense and I did see that post on Kirupa. What's missing from both examples is how I get the text into a Dynamic text field? So instead of this:
              Event.COMPLETE,
              Would I take out the trace statement and replace it with this?
              Event.COMPLETE,
              home_txt.text = evt.target.data.a;
              products_txt.text = evt.target.data.b;
              services_txt.text = evt.target.data.c;
              • 4. Re: AS 3.0 Loading external text from a text file
                padrepio Level 1
                I tried that and got this error:
                TypeError: Error #1034: Type Coercion failed: cannot convert flash.text::TextField@d59a4a9 to flash.display.MovieClip.
                Will Flash only import from a .txt file or will an .html file be OK too?
                Here are the variables from my file:
                home=Home&games=Games&activities=Activities&clubhouse=Club House
                Here is my AS code:
                // Load the text file, making sure the path itself is an instance of URLRequest
                loader.load(new URLRequest("buttons.html"));
                loader.addEventListener(Event.COMPLETE, function(evt:Event):void {
                home.htmlText = evt.target.data.home;
                games.htmlText = evt.target.data.games;
                activities.htmlText = evt.target.data.activities;
                clubhouse.htmlText = evt.target.data.clubhouse;
                That function constructor looks really weird.
                • 5. Re: AS 3.0 Loading external text from a text file
                  that data property is the entire string from your textfile. use trace(evt.target.data) to see what you're loading.
                  • 6. Re: AS 3.0 Loading external text from a text file
                    Level 7
                    padrepio,
                    I'm not sure what that error means, to be honest.
                    > be OK too?
                    An HTML file *is* a text file, just formatted a paticular way.
                    Traditionally, this sort of loading is done with files that end in the .txt
                    file extension.
                    I would urlencode that string, which means you should replace the space
                    in "Club House" with a %20; in otherwords ...
                    ... &clubhouse=Club%20House
                    > Here is my AS code:
                    So far, so good. That's the same.
                    Stil the same.
                    > URLRequest
                    I would load this as buttons.txt.
                    Is home a dynamic text field instance? Since your data aren't
                    HTML-formatted, I would use the TextField.text property ...
                    home.text = evt.target.data.home;
                    What function constructor?
                    David Stiller
                    • 7. Re: AS 3.0 Loading external text from a text file
                      funonmars Level 1
                      something else I notice that's different about the text files, is that in previous Flash ActionScript the text file would be like this:
                      &painting1=dumbo ate hay&painting2=cinderella was here&painting3=frosty paws&
                      with those &'s on either end essential, but now you need to drop them:
                      works. I didn't need to urlencode the text.
                      • 8. Re: AS 3.0 Loading external text from a text file
                        Level 7
                        funonmars,
                        > be like this:
                        Right ...
                        Huh? Nah. It has always been like this: name/value pairs are
                        separated by the ampersand character. There shouldn't be one at the very
                        beginning or at the very end, but it doesn't hurt to have them there.
                        If that's so, then it means Flash is getting more strict, which I would
                        argue is a good thing. The strings mentioned should always have been
                        urlencoded. The text field contains the same sort of string that would
                        appear in a query string, the kind that begins with a question mark and
                        lists name/value pairs separated by ampersands.
                        If what you're saying is true -- and I don't doubt you; just haven't
                        tested -- then this reminds me of switching to XHTML from the more relaxed
                        HTML. Many of the headaches in HTML come from its relaxed "standards" --
                        which, because they're so relaxed, often aren't standard at all.
                        David Stiller
                        • 9. Re: AS 3.0 Loading external text from a text file
                          actually, beginning and ending ampersands are no longer optional. they must be removed. the flash compiler is not happy unless each ampersand is between a value and a variable.
                          what is nice, though is if you assign the loaders dataFormat to be TEXT, you can load a text file without requiring the mytext=blah blah blah sort of thing that was required in as2. you can now load a standard text file.
                          • 10. Re: AS 3.0 Loading external text from a text file
                            padrepio Level 1
                            I've tried changing the html file to a .txt file. I also added an ampersand at the beginning of my variables:
                            I'm getting this error now: Error #2044: Unhandled ioError:. text=Error #2032: Stream Error. URL: file:///Macintosh%20HD/Users/alemieux/Desktop/Flash%5FActionScript3/LoadText/buttons.txt
                            at test_fla::MainTimeline/test_fla::frame1()
                            I get this error with or without the %20 in the Club House variable. Here are the variables in the text file:
                            &home=Home&games=Games&activities=Activities&clubhouse=Club House
                            • 11. Re: AS 3.0 Loading external text from a text file
                              there should be no ampersand before home.
                              but that compiler error is caused by an incorrect path to buttons.txt.
                              • 12. Re: AS 3.0 Loading external text from a text file
                                padrepio Level 1
                                Never mind. I got it!!! The ampersand at the beginning is a BIG NO NO! Don't do it! It returns an IO Error on the text file.
                                Thanks to all.
