0 Replies Latest reply on May 28, 2014 4:48 AM by AnalogKid17
    Pan/Zoom during transitions
    AnalogKid17 Level 1
      (This is a follow-up question to: How to automate pan/zoom ? - That issue itself was solved so I did not want to reopen that thread.)
      Version: Adobe Premiere Elements 12
      OS: Windows 7
      After creating a slideshow from Organizer > Create Slide Show, the pan/zooms are added but they only start after the 2 second transition is finished.
      The result is that the slideshow does not flow as it should.
      If I import the Slide Show in Premiere Elements Editor and open Motion under Applied Effects, I see that in fact the key frames are 2 seconds from the start. I can manually move them 2 seconds back to obtain the desired effect, but that can be tedious for a long slide show.
      Is there a way to set this in batch or to have the slide show creator do it right in the first place ?
