4 Replies Latest reply on May 30, 2014 2:42 AM by joel_pau
    How to get Parent Symbol name of current e.target element ?
    cnachos
      How can I get the Parent Symbol name of the current e.target element ?
      would that involve using this ?
      getParentSymbol()
      Thanks for the help
        • 1. Re: How to get Parent Symbol name of current e.target element ?
          Sudeshnasarkar27 Adobe Employee
          Hi ,
          I created a composition where I am trying to access the parent symbol of a rectangle. The structure is like this -
          Stage->parentMainSymbol->ChildSymbol->childRectangle. Now for the parentMainSymbol click , to access the rectangle element(which is the target) you can use the following snippet -
          sym.getComposition().getStage().getSymbol("parentMainSymbol").getSymbol("ChildSymbol").$(" childRectangle")
          Now, the parent of this is ChildSymbol whose reference could be obtained by -
          sym.getComposition().getStage().getSymbol("parentMainSymbol").getSymbol("ChildSymbol").$(" childRectangle")[0].offsetParent
          The info about the parent symbol is just being printed in the console view for the attached composition. This would print it out for -
          #Stage_parentMainSymbol_childSymbol which is the parent symbol of the target childRectangle under consideration.
          Kindly, take a look and let me know if it solves your problem.
          Thanks and Regards,
          Sudeshna Sarkar
          • 2. Re: How to get Parent Symbol name of current e.target element ?
            cnachos Level 1
            Thanks for the reply but this is not what i'm looking for.
            I'm trying to find a way to get the PARENT SYMBOL NAME of any targeted element on the stage by using the e.target so that I don't need to specify any symbol name manually.
            Example:
            On stage, I have a symbol name "symContainer" and inside that symbol I have 3 elements called shape1, shape2, shape3. When i'm using EVENT like a Mouseover to apply a css properties change  using the e.target, it will change the properties of the target elements but I want to change the parent symbol properties only. I want a way to GetElementSymbolParent so that I can change properties of the parent symbol only.
            is there a e.target.parent or anything of that  sort ?
            • 3. Re: How to get Parent Symbol name of current e.target element ?
              Hi ,
              I have created another sample which has a main parent symbol "symContainer" containing 3 shapes - Shape1 , Shape 2, Shape 3. The logic is written on mouseover of shape 2(which is the green rounded rectangle) and on mouseover it would return(in the console view print) - symContainer which is the parent symbol.
              console.log(sym.getSymbolElementNode().id);
              Hope this helps!
              Thanks and Regards,
              Sudeshna Sarkar
              • 4. Re: How to get Parent Symbol name of current e.target element ?
                joel_pau Level 5
                You can also try: sym.getSymbolTypeName()
                ==> Here is a demo file: https://app.box.com/s/08kwggkuwnzfx61gwgad
