1 Reply Latest reply on May 20, 2007 7:43 AM by BLXWebMaster
    datagridcolumn visible=false acting weird
    Laeder
      Hi everybody!
      I have problems with a few columns that shows up again when I do send to the httpService that is the dataProvider to the datagrid. The stay hidden if I use a repeater, but not when I use the httpService. I downloaded the hotfix hoping for a solution, but that didn't not solve it.
      Is there a work around, or do I have to wait for next hotfix?
        • 1. Re: datagridcolumn visible=false acting weird
          BLXWebMaster
          I have experienced several issues with this issue. Although the latest version addressed most of them, there seems to be certain instances where it still happens.
          Try this.
          Create a function like.
          public function setHiddenColumns():void {
          LastActivityDate.visible = false;
          OwnerName.visible = false;
          Then call the function on CreationComplete and after your remote object result.
          Also, I have noticed some different results with how your DataGrid columns are ordered in your code. Try putting a field that is always visible as the last column. So, make sure you don't have a hidden column as your last column. It fixed my issue.
