1 Reply Latest reply on Jun 5, 2014 5:27 AM by jfb00
    How to call HTTPservice for Java server side method and get JSON data.
    sathishnataraj
      Hi Guys,
      I'm learning Flex. I need your advise on the below.
      Motive : Retrieve data from Oracle 11g DB, and Display in Flex Datagrid.
      Hibernate - For Database data retrieval
      Java - Backend processing
      JSON - (Net sf json).
      * Create JSON object ( Put Java model data ex: Product)
      * Create JSON array ( Put all models data : All products)
      * Create JSON object ( put JSON array as Object : Ex: Products, All Products)
      * Return JSON object to Flex
      I was able to retrieve JSON data from a Website as below and it got displayed in Datagrid.
      I want to achieve the same for my server side Java Method (Preferably want to call Spring controllers method and handle it in backend and return JSON data to Flex).
      <s:HTTPService id="httpService"
          url="https://raw.githubusercontent.com/kronusme/dota2-api/master/data/heroes.json"
          resultFormat="text" method="POST" useProxy="false" result="onJSONLoad(event)"/>
      <s:RemoteObject id="po" destination="sebService" result="po_resultHandler(event)" />
      This remote object returns data but when I try to do JSON.parse in Flex, I get Unexpected Exception o encountered.
      I did lot of research on how to call the server side Java method from Flex HTTPService and couldn't find any help .
      Thanks in advance.
      Regards,
      Sathish Nataraj
