1. Re: Air 14.0.0.103 for Android + Flash CC publish error
Nimisha1 May 29, 2014 10:58 PM (in response to Ulimetic) -
2. Re: Air 14.0.0.103 for Android + Flash CC publish error
Ulimetic May 30, 2014 3:55 AM (in response to Nimisha1)It happens when I publish to a connected android device.. This is a Stage3D/Starling project, not sure if it matters.
Can publish with 13.0.0.83, but not 14.0.0.103 (Also previous version of AIR14 didn't cause the bug)..
3. Re: Air 14.0.0.103 for Android + Flash CC publish error
Nimisha1 May 30, 2014 4:13 AM (in response to Ulimetic)Can you please try out publishing a HelloWorld app on your machine as on our end we are not able to reproduce the issue with a HelloWorld app? It would be really helpful to narrow down the issue. Also please mention the Windows OS version and Java version.
-Nimisha
4. Re: Air 14.0.0.103 for Android + Flash CC publish error
Ulimetic Jun 6, 2014 6:30 AM (in response to Nimisha1)Windows 7 x64
Java version 7 update 60
Tried again and same result, can't strip down to a hello world, it uses Starling/Stage3D...
5. Re: Air 14.0.0.103 for Android + Flash CC publish error
katopz@sleepydesign.com Jun 7, 2014 8:28 AM (in response to Nimisha1)Hi Nimisha
same here Bug#3771841 - Export release build captive runtime throw aapt tool failed
just new empty project is enough to reproduce this issue btw.
Best
6. Re: Air 14.0.0.103 for Android + Flash CC publish error
Nimisha1 Jun 10, 2014 12:22 AM (in response to katopz@sleepydesign.com)Hi Ulimetic and Katopz,
Are you trying to overlay the _103 SDK or any latest SDK over the _96 SDK, if yes then please don't overlay latest SDK on the _96 SDK and instead use the latest SDK directly(no need to overlay) from the option FLash Pro-> Help-> Manage Adobe AIR SDK..?
Please let us know if it is working for you.
Nimisha
7. Re: Air 14.0.0.103 for Android + Flash CC publish error
katopz@sleepydesign.com Jun 10, 2014 1:22 AM (in response to Nimisha1)Hi Nimisha
it's Flash Builder 4.7 present version in my case and overlay you mean copy and paste (replace all) over old SDK? so yes i did that for many years without any problems. and IMHO "replace all" should have same effect.
but, guess what use all new AIRSDK folder did the trick,it's just working
and yes it's totally confuse me tho
8. Re: Air 14.0.0.103 for Android + Flash CC publish error
Ulimetic Jun 10, 2014 7:33 AM (in response to katopz@sleepydesign.com)Here it's a Flash CC PRO build. I removed the 96 and added 103 in flash CC... Same issue... Only happens when publishing Android to device.
9. Re: Air 14.0.0.103 for Android + Flash CC publish error
Ulimetic Jun 10, 2014 7:52 AM (in response to Ulimetic)Ok now it's fine, I deleted everything and re added everthing.
