1 Reply Latest reply on May 29, 2014 8:57 AM by Willi Adelberger
    InDesign Mavericks Issue 10.9.2
    billricoh
      Hello,
      I have a customer that is having a issue printing to 100% of scale after upgrading to Mavericks 10.9.2. The applications this is happening out of is InDesign,Acrobat Reader, and Acrobat Pro as well. They all want to scale to fit the page (rather than 100% scale or at a reduced scale). They are printing on a new Ricoh MPC3503 that is compatible with 10.9.2 Mavericks. Any suggestions or fixes?
      Bill
        • 1. Re: InDesign Mavericks Issue 10.9.2
          1. This setting is part of the print dialog and must be supported of the used print driver.
          2. Scale to fit page will reduce scale if the PDF will not fit between the printer borders.
          3. You can set the default behaviors in the PDF's document properties, where you can find some settings for printing, if the document is opened in Acrobat or Reader and if the printer driver support this property. If the PDF is opened in another viewer these settings are ignored.
