0 Replies Latest reply on May 29, 2014 8:13 AM by knoseworthy
    changePath or Rename functionality different from OSx / Windows
    knoseworthy
      Created a script that on a windows environment using the 'Rename' method can also change the path / location of the file where on OSx enviroment it fails
      So on OSx I've tried the changePath method all i get is a folder created of the file name.  Any incite would be fantastic .
      The script below is a sample it does read a tab text file to get source and destination names - but the piece at the end of changePath and rename both fail on OSx - i've run this in photoshop,extendscript,indesign and works on windows.
      var textFile = File.openDialog ("Open Data Excel Sheet", "*.txt,*.csv",false);
      var imageDir = Folder.selectDialog("Select Source Directory");
      var destinationDir = Folder.selectDialog("Select Destination");
      var line = 0;
      var articleColumn = 7;
      var upcColumn= 9;
      var filetype = "*.tif";
      var upctoart = [];
      if(textFile != null && imageDir != null && destinationDir != null){
      textFile.open('r');
      while(!textFile.eof)
      var row = textFile.readln();
      var cols = row.split("\t");
      upctoart[cols[upcColumn]]=cols[articleColumn];
      /*if(line == 25)
          alert(cols[upcColumn] + '----' + cols[articleColumn]);
      line++;
      textFile.close();
      var files = imageDir.getFiles(filetype);
      for(var i = 0; i < files.length; i++)
      //alert (files[i].fullName);
      var f = files[i];
      var fileName = f.name;
      var fs = fileName.split("_");
      if(typeof upctoart[fs[0]] == 'undefined')
      continue;
      var artNum = upctoart[fs[0]];
      var destinationFileName = fileName.replace(fs[0],artNum);
      try{
      f.rename(destinationFileName);
      f.changePath (destinationDir.fullName + '/');
      }catch(err){}
      alert('Done');
