1 Reply Latest reply on May 29, 2014 4:35 PM by A.T. Romano
    Using PE12 I can not render files the files loose focus and flicker?
    Rico1108
      My computer is a iMac osx version 10.9.3. On 05/02/14, I downloaded PE12. every time I try to render the files in my project, the files flicker loose focus.
        • 1. Re: Using PE12 I can not render files the files loose focus and flicker?
          A.T. Romano Level 7
          rico1108
          Premiere Elements 12 Mac
          When you talk about rendering are you referring to rendering as in rendering the Timeline to get the best possible preview of the playback of the Timeline content in the Edit area monitor?
          What are the properties of this Timeline content? All video files?
          Video compression
          Audio compression
          Frame Size
          Frame Rate
          Interlaced or Progressive
          File Extension
          Pixel Aspect
          and/or Brand/Model/Settings for camera which record the source video
          Do the properties of your source video match the properties of the project preset that you or the project set? If you let the project do the set based on the properties of the first video drag to the Timeline, please tell us the set details that you find under Edit Menu/Project Settings/General and its Editing Mode, Timebase, Frame Size, and Pixel Aspect Ratio readings even if they look grayed out.
          If you are really talking about rendering as in the export sense of the word, please include with the above the export choice under Publish+Share/.......and preset and any customization of it under the Advanced Button/Video Tab and Audio Tab.
          Let us start here and then customize the troubleshooting based on your details.
          Thank you.
          ATR
