1. Re: Using a tablet with Photoshop CC
Chris Cox May 29, 2014 5:46 PM (in response to mentalcase129)The brush options should only appear on a right click. Check the wacom control panel and make sure you have the button press set for a normal click. And make sure you are not pressing the rocker switch on the pen when you press down.
2. Re: Using a tablet with Photoshop CC
buttonBright Oct 17, 2014 2:29 PM (in response to mentalcase129)I was having same problem using Photoshop cc and windows 8.1.
I first noticed when I was using clone tool. If I held down pen to start painting from clone source the dang circle appears with brush options.
Here's what I did to fix it.
Make sure your tablet is plugged in and working.
Go to Windows Control Panel
Select Hardware and Sound.
"Pen and Touch" should be listed, and select "Change Tablet Pen Settings".
A dialog opens. Look for the box that has the line inside that says "Press and Hold", and select that line.
Then press Settings button under box. This opens a new dialog box. At the top you need to UNCHECK "Enable Press and Hold for right-clicking". Hit OK, etc.
That seemed to fix problem.
It seems under windows the default way pens work is that pressing and holding is equal to a right click. So unchecking that turns this off.
I also disabled "Flicks" as well in same dialog box and I thought it may affect how my pen works when drawing.
