10 Replies Latest reply: Jun 4, 2014 5:56 AM by xsinner72 RSS
    Why am I getting '500 Internal server error' after installing CF 10?
    xsinner72 Community Member
      Hello,
      I am not able to get to CF admin after installing CF 10. I am getting a '500 internal server error' along with the following message. How do I get around it? Thanks.
      Best regards,
      Chung Lee
      type Exception report
      message
      description The server encountered an internal error () that prevented it from fulfilling this request.
      exception
      javax.servlet.ServletException: java.lang.NullPointerException coldfusion.bootstrap.ClassloaderHelper.initServletClass(ClassloaderHelper.java:129) coldfusion.bootstrap.BootstrapServlet.init(BootstrapServlet.java:59) org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472) org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98) org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:928) org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:414) org.apache.coyote.ajp.AjpProcessor.process(AjpProcessor.java:203) org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:539) org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:298) java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145) java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615) java.lang.Thread.run(Thread.java:722)
      root cause
      java.lang.NullPointerException coldfusion.CfmServlet.init(CfmServlet.java:82) coldfusion.bootstrap.ClassloaderHelper.initServletClass(ClassloaderHelper.java:121) coldfusion.bootstrap.BootstrapServlet.init(BootstrapServlet.java:59) org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472) org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98) org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:928) org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:414) org.apache.coyote.ajp.AjpProcessor.process(AjpProcessor.java:203) org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:539) org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:298) java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145) java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615) java.lang.Thread.run(Thread.java:722)
      note The full stack trace of the root cause is available in the Apache Tomcat/7.0.23 logs.
        • 1. Re: Why am I getting '500 Internal server error' after installing CF 10?
          Anit Kumar Panda Employee Hosts
          HI xsinner72,
          ColdFusion and IIS both should have same bitness. If CF is installed in 64-bit mode, then change the App pool (Enable 32 bit applications” set to false) under Advanced Settings. Remove the connector and recreate it.
          Once done, launch command prompt as administrator and try iisreset command. Now you can test your site/CF Admin.
          Regards,
          Anit Kumar
          • 2. Re: Why am I getting '500 Internal server error' after installing CF 10?
            Hello Anit,
            Thanking your for your reply. The 'enable 32-bit application' was already default to false. When you say 'remove the connector', do you mean delete the site's app pool?
            Best regards,
            Chung Lee
            • 3. Re: Why am I getting '500 Internal server error' after installing CF 10?
              Hi Chung,
              ColdFusion and IIS both should have same bitness. Can you confirm this?
              To remove/recreate the connector. Launch the Web Server Configuration Tool as admin, from the Start>>All Programs menu, and delete the existing connector and then recreate it.
              Regards,
              Anit Kumar
              • 4. Re: Why am I getting '500 Internal server error' after installing CF 10?
                Hello Anit,
                Both ColdFusion and IIS are 64-bit.
                I have removed and recreated the connector. This time I am getting 'the service is unavailable' error. Am I getting close? Thanks.
                Best regards,
                Chung
                • 5. Re: Why am I getting '500 Internal server error' after installing CF 10?
                  Yes definitely. The initial issue was due to a bad connector (seems like).  For Service unavailable, can you refer to ColdFusion 11 IIS Connector Tuning — Adobe ColdFusion Blog. This blog holds good for both ColdFusion 10 and ColdFusion 11.
                  xsinner72 wrote:
                  Hello Anit,
                  Best regards,
                  Chung
                  Regards,
                  Anit Kumar
                  • 6. Re: Why am I getting '500 Internal server error' after installing CF 10?
                    Hello Anit,
                    I have just tried the connector tuning couple of times by following instructions on the blog. I am using the Case# 1 setting on the blog. I am still getting 'the service is unavailable' error. Thanks.
                    Best regards,
                    Chung
                    • 7. Re: Why am I getting '500 Internal server error' after installing CF 10?
                      Can you share your worker.properties?
                      Can you also check, what is the error you are getting in exception.log?
                      Regards,
                      Anit Kumar
                      • 8. Re: Why am I getting '500 Internal server error' after installing CF 10?
                        Anit,
                        The following is from the workers.properties:
                        worker.list=cfusion
                        worker.cfusion.type=ajp13
                        worker.cfusion.host=xxx.xxx.xxx.xx (My work does not allow me to reveal IP address.)
                        worker.cfusion.port=8012
                        worker.cfusion.max_reuse_connections=250
                        worker.cfusion.connection_pool_size=500
                        worker.cfusion.connection_pool_timeout=60
                        As for the exception log, it's showing the following:
                        "Error","pool-2-thread-1","06/02/14","13:00:00",,"Unable to initialise Monitoring service: java.lang.NoClassDefFoundError: Could not initialize class coldfusion.featurerouter.FeatureRouter"
                            at coldfusion.server.CFService.setupMonitoringService(CFService.java:464)
                            at coldfusion.server.CFService.start(CFService.java:671)
                            at coldfusion.server.j2ee.CFStartUpServlet.startCFService(CFStartUpServlet.java:110)
                            at coldfusion.server.j2ee.CFStartUpServlet.init(CFStartUpServlet.java:86)
                            at javax.servlet.GenericServlet.init(GenericServlet.java:160)
                            at coldfusion.bootstrap.ClassloaderHelper.initServletClass(ClassloaderHelper.java:121)
                            at coldfusion.bootstrap.BootstrapServlet.init(BootstrapServlet.java:59)
                            at org.apache.catalina.core.StandardWrapper.initServlet(StandardWrapper.java:1266)
                            at org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:1185)
                            at org.apache.catalina.core.StandardWrapper.load(StandardWrapper.java:1080)
                            at org.apache.catalina.core.StandardContext.loadOnStartup(StandardContext.java:5001)
                            at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5278)
                            at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
                            at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1525)
                            at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1515)
                            at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334)
                            at java.util.concurrent.FutureTask.run(FutureTask.java:166)
                            at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
                            at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
                            at java.lang.Thread.run(Thread.java:722)
                        "Warning","Thread-10","06/02/14","13:00:00",,"Graphing service is unavailable"
                            at coldfusion.graph.GraphingServiceImpl.setUpWatermark(GraphingServiceImpl.java:220)
                            at coldfusion.graph.GraphingServiceImpl._initializeGraphingEngine(GraphingServiceImpl.java:1 44)
                            at coldfusion.graph.GraphingServiceImpl.access$300(GraphingServiceImpl.java:40)
                            at coldfusion.graph.GraphingServiceImpl$2.run(GraphingServiceImpl.java:125)
                        "Error","Thread-12","06/02/14","13:00:01",,"The Runtime service is not available. This exception is usually caused by service startup failure. Check your server configuration."
                        coldfusion.server.ServiceFactory$ServiceNotAvailableException: The Runtime service is not available.
                            at coldfusion.server.ServiceFactory.getRuntimeService(ServiceFactory.java:117)
                            at coldfusion.document.DocumentServiceImpl.initializeDocumentService(DocumentServiceImpl.jav a:219)
                            at coldfusion.document.DocumentServiceImpl.access$000(DocumentServiceImpl.java:52)
                            at coldfusion.document.DocumentServiceImpl$1.run(DocumentServiceImpl.java:180)
                        --Chung
                        • 9. Re: Why am I getting '500 Internal server error' after installing CF 10?
                          This needs to be analyzed in more detail. Can you send an email to cfinstal<AT>adobe<DOT>com, making a reference to this thread.
                          Regards,
                          ANit Kumar
                          • 10. Re: Why am I getting '500 Internal server error' after installing CF 10?
                            Will do, Anit. Thank you very much.
                            Best regards,
                            Chung Lee
