If
Hello everyone, I am making a document that needs some formulating/scripting done in it and out of all the forums, I cant find anything to work.
This is what I have.
Field 1 (Value) Field 2 (Value) Field 3 (result); The result field will also round to the nearist thousands (Round((horsepower / weight)/.01)*.01; now after that I need another field to use the "if" statement to put a value in another field if the result matches the result field. I know I am making this complicated but let me show you what I have.
The first field is a numeric field that the user will input their horsepower.
The second field is a numeric field that the user will input their weight.
The third field is a numeric field that will auto sum the first to fields and round to the nearist thousands
All the steps above are working awesomely. The part I cant get to work is the "if" statement in the fourth Field.
I tried useing this code to make it work but i keep getting an error about the "ratio" field
If (data0 eq "0") then qqq0 = "1" elseif (data0 eq "0.1") then qqq0= "1" elseif (data0 eq "0.10") then qqq0= "1" endif
I used this script with Formcalc and it works on everything else. I think the "round" formula is causing the problem. Also the elseif i used up to 0.35, so 35 lines of code.
Any help would be greatly appreciated. Thanks.
