4 Replies Latest reply on Jun 1, 2014 2:54 AM by virender_CTS
    How to know which text frame's page number in cs6?
    virender_CTS Level 1
      Hello all,
      I want to know page number of selected textframe. I tried different properties but unable.
      Help need on this line:      alert(i + " " + myFrame.id + "   " + myFrame.parentPage.id);  // here i want page number to be displayed
      #target Indesign
      var myDoc = app.documents.item(0);
      var i;
          for(i=0; i < myDoc.textFrames.length; i++)
              var myFrame = myDoc.textFrames[i];
          myFrame.select();
      thanks
      virender
        • 1. Re: How to know which text frame's page number in cs6?
          pixxxel schubser Most Valuable Participant
          Hi virender_CTS;
          try:
          myFrame.parentPage.name
          Have fun.
          • 2. Re: How to know which text frame's page number in cs6?
            AS Scripter Level 1
            In Applescript:
            tell application "Adobe InDesign CS6"
              return name of parent page of selection -->  "7"
            end tell
            • 3. Re: How to know which text frame's page number in cs6?
              @Virender –if you need a Number, not a String – name is a string object – you could use the value of documentOffset for the parentPage. It starts with the number 0 on page 1 of a document. Regardless of the name. A name for page 1 could well be "0020" or "20" or "XX". Or "1".
              And a name is not unique. If more than one section is present a name like "1" could there more than one time.
              myFrame.parentPage.documentOffset;
              However, parentPage could be null, if the object is sitting on the pasteboard.
              And as you are looping through all textFrames of a document, this could well be.
              Instead loop through all pages of the document. And from that through all textFrames.
              Then you can be sure, that all textFrames you are visiting have a valid parentPage property.
              Or do it like that:
              if(myFrame.parentPage != null){
              $.writeln(myFrame.parentPage.documentOffset +"\t"+ myFrame.parentPage.name +"\t"+ myFrame.id)
              Oh, just another question:
              Why would you like to select myFrame with: myFrame.select() ?
              What would you hope to accomplish by doing that?
              Uwe
              • 4. Re: How to know which text frame's page number in cs6?
                Hi Uwe,
                thanks for your help on the document offset.
                For your question about myFrame.select() is. In a monthly publication where page heading and numbers remains same but the content changes.
                Few month ago, i created a script to import text on selected text frames and for that i need their frame Id or frame label.
                I found frame id is the best option as per my best knowledge on scripting. so i used above mentioned script to know the required frame ID and then assign respective rtf file for import on specific frame ID.
                thanks again
                Virender
