Still getting used to Livecycle and not attempting to make a effort at learning Javascript at the same time. I'm was attempting to work on a form in ES4 that would use the following formula to convert a date that someone selects from a date picker to then convert that date to show MM/YYYY in a new field. I would appreciate it if anyone has a couple of seconds to take a look at this and tell me what I'm missing to make this work.
Corey
form1.#subform[0].DateField2::calculate - (JavaScript, client)
DateField1.rawValue
form1.#subform[0].DateField3::calculate - (JavaScript, client)
var date = new Date(DateField1.rawValue);
var month = date.getMonth()+1;
var year = date.getFullYear();
if (DateField1.rawValue == null)
{this.rawValue="";}
else
if (month<=03) month="03";
if (month<=06) month="06";
if (month<=09) month="09";
if (month<=12) month="12";
this.rawValue = month+"/"+date.getFullYear();
Views
Total Likes
to make this work the field that shows the quarters cannot be a date field.
You should use a text field instead.
form11.#subform[0].Textfield1::calculate - (FormCalc, client)
if (not DateField1.isNull) then
var vDate = Date2Num(DateField1.formattedValue, "MM/DD/YYYY")
var vMonth = Num2Date(vDate, "M")
var vYear = Num2Date(vDate, "YYYY")
var vQuarter
if (Within(vMonth, 1, 3) eq 1) then
vQuarter = "03"
elseif (Within(vMonth, 4, 6) eq 1) then
vQuarter = "06"
elseif (Within(vMonth, 7, 9) eq 1) then
vQuarter = "09"
else
vQuarter = "12"
endif
$ = Concat(vQuarter, "/", vYear)
else
$ = null
endif
Views
Total Likes
Any way to convert this in Javascript?
Views
Total Likes
