3 Replies Latest reply on Jun 1, 2014 11:34 AM by A.T. Romano
    Using Premiere Elements 12 to edit iPhone 5 video, the published .MP4 is choppy when the video moves quickly
    cwsteini Level 1
      I am using Premiere Elements 12 up to date.
      I am editing iPhone 5 video shot with the following specs:
      Type: MPEG Movie (.MOV file extension)
      File size: not exceeding 300 MB
      Image Size: 1920x1080
      Frame Rate: 30.00
      Source Audio Format: 44100 Hz - compressed - Mono
      Project Audio Format: 44100 Hz - 32 bit floating point - Mono
      Total Duration: not exceeding 3 minutes
      Pixel Aspect Ratio: 1.0
      Project Settings:
      General:
      Editing Mode: DSLR
      Timebase: 30.00 frames/second
      - Video
      Frame Size: 1920 horiz 1080 vert
      Pixel Aspect Ratio: Square Pixels (1.0)
      Fields: No Fields (Progressive Scan)
      Display Format: 30fps Timecode
      - Audio
      Sample Rate: 48000 Hz
      Display Format: Audio Samples
      Capture:
      Capture Format: DV
      Video Rendering:
      - Previews
      File Format: I-Frame Only MPEG
      Compressor: MPEG I-Frame
      checked = Optimize Stills
      If I publish under Computer and select AVCHD
      choose: MP4 - H264 1920x1080p 30
      File Type: H.264
      Frame Size: 1920 x 1080
      Frame Rate [fps]: 29.97
      Audio Setting: AAC, 160 kbps, 48 kHz, Stereo
      File Size: 1531.05 MB
      Duration: 6 Min, 30.00 Sec
      The video is choppy whenever there is moderate movement.
      During playback in premiere it is perfectly smooth.
      All I want to do is to be able to share this video online on youtube, Facebook and be able to watch it back on my computer at fairly high quality but I am willing to compromise in order to get it all to play smoothly.
      Q1) What should I be outputting this as to accomplish what I have just said?
      Q2) The video should only be like 3 minutes long after editing it but it seems to have about 3 minutes of black screen at the end. How do I get rid of this black bit at the end??
        • 1. Re: Using Premiere Elements 12 to edit iPhone 5 video, the published .MP4 is choppy when the video moves quickly
          A.T. Romano Level 7
          cwsteini
          Unless you have the information in front of you, please download and install the MediaInfo video properties readout program to determine the frame rate or frame rates of your video. Cell phone video is often characterized by variable frame rate which can (not always) create problems in getting the video imported at all, out of sync audio....
          MediaInfo - Free download and software reviews - CNET Download.com
          Be on guard for any unwanted carry alongs with the MediaInfo. Great program, but those carry alongs can be a major nuisance. The readout of that program will tell us constant versus variable frame rate.
          Also check the readout to confirm that your are working with progressive rather than interlaced video.
          If variable frame rate, the next step would be to take the video into HandBrake and export it as H.264.mp4 with a constant rather than variable frame rate. Use the middle value between the min and max.
          We will be watching for your results.
          Thank you.
          ATR
          • 2. Re: Using Premiere Elements 12 to edit iPhone 5 video, the published .MP4 is choppy when the video moves quickly
            cwsteini Level 1
            A.T. Romano,
            Thank you for your quick response.
            Some additional information that I left out from my first post:
            I am running: Adobe Premiere Elements Version 12.1
            On: 11-inch Mid 2011 Macbook Air 4,1
            OS: Mac OSX Mavericks 10.9.3 (13D65)
            Processor: 1.6 GHz Intel Dual Core i5 [L2 Cache (per core): 256 KB]
            Memory: 2 GB 1333 MHz DDR3
            SSD: Samsung 260 Gb w/140 Gb free
            Graphics: Intel HD Graphics 3000 288 MB
            and I am viewing on my standard 11-inch (1366 x 768) display.
            Just so you and others who may find this thread helpful have the full picture of my situation.
            Media Info Results:
            General
            Complete name : ..\IMG_1249.MOV
            Format : MPEG-4
            Format profile : QuickTime
            Codec ID : qt
            File size : 174 MiB
            Duration : 1mn 45s
            Overall bit rate : 13.8 Mbps
            Recorded date : 2014-05-27T18:23:33-0500
            Encoded date : UTC 2014-05-27 23:23:33
            Tagged date : UTC 2014-05-27 23:23:45
            Writing application : 7.0.4
            Writing library : Apple QuickTime
            Model : iPhone 5
            ©xyz : +43.0273-088.2103+293.675/
            Make : Apple
            com.apple.quicktime.make : Apple
            com.apple.quicktime.creationdate : 2014-05-27T18:23:33-0500
            com.apple.quicktime.location.ISO6709 : +43.0273-088.2103+293.675/
            com.apple.quicktime.software : 7.0.4
            com.apple.quicktime.model : iPhone 5
            Video
            Format : AVC
            Format/Info : Advanced Video Codec
            Format profile : High@L4.1
            Format settings, CABAC : Yes
            Format settings, ReFrames : 1 frame
            Format settings, GOP : M=1, N=30
            Codec ID : avc1
            Codec ID/Info : Advanced Video Coding
            Duration : 1mn 45s
            Source duration : 1mn 45s
            Bit rate : 13.7 Mbps
            Width : 1 920 pixels
            Height : 1 080 pixels
            Display aspect ratio : 16:9
            Frame rate mode : Variable
            Frame rate : 29.970 fps
            Minimum frame rate : 28.571 fps
            Maximum frame rate : 30.000 fps
            Color space : YUV
            Chroma subsampling : 4:2:0
            Bit depth : 8 bits
            Scan type : Progressive
            Bits/(Pixel*Frame) : 0.221
            Stream size : 173 MiB (99%)
            Source stream size : 173 MiB (99%)
            Title : Core Media Video
            Color primaries : BT.709
            Transfer characteristics : BT.709
            Matrix coefficients : BT.709
            Audio
            Format : AAC
            Format/Info : Advanced Audio Codec
            Format profile : LC
            Codec ID : 40
            Duration : 1mn 45s
            Bit rate mode : Constant
            Bit rate : 64.0 Kbps
            Channel(s) : 1 channel
            Channel positions : Front: C
            Sampling rate : 44.1 KHz
            Compression mode : Lossy
            Stream size : 810 KiB (0%)
            Source stream size : 811 KiB (0%)
            Title : Core Media Audio
            So gleaning the important details from that:
            Video was shot on: iPhone 5 running iOS 7.0.4
            Resolution: 1920 x 1080
            Format: MPEG-4 (.MOV)
            Video -
            Format: AVC (Advanced Video Codec)
            Format Profile: High@L4.1
            Format Settings: CABAC (lossy compression)
            Bit rate: 13.7 Mbps
            Display aspect ratio: 16:9
            Frame rate mode: Variable
            Frame rate: 29.970 fps
            Minimum frame rate: 28.571 fps
            Maximum frame rate: 30.000 fps
            Scan type: Progressive
            So we have a variable frame rate and progressive scan...
            Handbrake:
            I then downloaded the latest version of handbrake as you instructed for free directly from their website.
            What I ended up doing (just because it's what I tried first and it worked really well) was to take the .MP4 files that Adobe Premiere Elements 12.1 had outputted (through the publishing process) and loaded them into handbrake. These were the .MP4 file/movies that were supposed to be my finished product but had the problem of being all choppy/skippy/jumpy (all synonyms to describe what I was experiencing with the videos).
            Output Settings (for Handbrake): Custom
            Format: MP4 file
            Web Optimized: Check
            Video -
            Video Codec: H.264 (x264)     Framerate (FPS): 29.97 (NTSC Video) & Constant Framerate
            Video Quality: Constant Quality     RF: 20 (I tested them at 20, 10, 5, 4, 3, and 0 and chose 20 because I really couldn't see much difference with the higher quality)
            x264 Preset: medium
            x264 Tune: film
            H.264 Profile: auto
            H.264 Level: 4.0
            Before starting I always did a 15 second "Preview Window" which I think is a really cool feature to see what the end video will look like andy verify my settings before running the long render process.
            The resulting .MP4's were totally cured of their choppy qualities and played beautifully smooth and in Full HD.
            Thanks you A.T. Romano so much for suggesting Handbrake and explaining what to do! I hope others will find this explanation/instructional helpful!
            • 3. Re: Using Premiere Elements 12 to edit iPhone 5 video, the published .MP4 is choppy when the video moves quickly
              A.T. Romano Level 7
              cwsteini
              Thank you for the detailed reply which is appreciated and will be very helpful to all.
              You did very well sorting through the troubleshooting details to a successful conclusion.
              Best wishes as you move forward in your Premiere Elements projects.
              ATR
