4 Replies Latest reply on May 31, 2014 10:27 AM by El León
    same url but one work and the other does not
    El León Level 1
      Placed a url in a composition of the Edge Animate to click on it to go to that url, but not up the url but it says NOT FOUND. But the direction in page not found is the same as the page that appears in catalyst bussines, so I do not understand what is happening.
        • 3. Re: same url but one work and the other does not
          hemanthR Adobe Employee
          Did you check with catalyst team if there are any configuration settings which is causing this?
          • 4. Re: same url but one work and the other does not
            El León Level 1
            In Edge Animate is being created is a note with debug information:
            [0531/123810: INFO: dhcp_proxy_script_adapter_fetcher_win.cc (267)] Error fetching URL from DHCP PAC 2
            But before creating the next note -debug :
            [ 0531 / 114728 : INFO : dhcp_proxy_script_adapter_fetcher_win.cc ( 267 )]
            [ 0531 / 114739 : INFO : dhcp_proxy_script_adapter_fetcher_win.cc ( 267 )]
            [ 0531 / 120215 : ERROR : ipc_channel_win.cc (401 )]
            pipe error: 232
            [ 0531 / 120441 : INFO : dhcp_proxy_script_adapter_fetcher_win.cc ( 267 )]
            [ 0531 / 120452 : INFO : dhcp_proxy_script_adapter_fetcher_win.cc ( 267 )]
            [ 0531 / 120555 : INFO : dhcp_proxy_script_adapter_fetcher_win.cc ( 267 )]
            [ 0531 / 121234 : INFO : dhcp_proxy_script_adapter_fetcher_win.cc ( 267 )]
            [ 0531 / 121251 : INFO : dhcp_proxy_script_adapter_fetcher_win.cc ( 267 )]
            [ 0531 / 121702 : INFO : dhcp_proxy_script_adapter_fetcher_win.cc ( 267 )]
            [ 0531 / 121713 : INFO : dhcp_proxy_script_adapter_fetcher_win.cc ( 267 )]
            [ 0531 / 121827 : INFO : dhcp_proxy_script_adapter_fetcher_win.cc ( 267 )]
            [ 0531 / 122023 : ERROR : ipc_channel_win.cc (401 )] pipe error: 232
            But I do not know what it means or what to do.
            Thank you for your help
